Old 03-12-2013, 10:59 PM   #1
olrosa
olrosa's Avatar
Spring rubber spacers
Has anyone ever used the spring rubbers that go in between the coils on the front to stiffen up the ride. Like the ones used in circle track racing. I like my ride height but I have a BB and its a little squishy and bottoms out sometimes
olrosa is offline   Reply With Quote
Old 03-13-2013, 08:56 AM   #2
SCOTI
SCOTI's Avatar
Re: Spring rubber spacers
Circle track guys use spring rubbers for tuning. You would be using them to compensate for a deficiency. I would just get new springs w/the proper spring rate for your big block.
Is it a factory original big block truck?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-13-2013, 10:14 AM   #3
olrosa
olrosa's Avatar
Ya that makes more since. Who sell springs with the diff load rates?
Old 03-13-2013, 10:19 AM   #4
olrosa
olrosa's Avatar
I bought cpp lowering springs already and had to cut about 3/4 coil off for the stance I want. It's not bad, I would just like a little stiffer
Old 03-13-2013, 10:35 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
If you cut 3/4 of a coil off of a lowered spring, it may be too short now, causing the bottoming out. Did you replace your shocks too? That might help since you have already replaced the springs. Do you have a sway bar? If its "a little squishy" in the turns, a sway bar will be a big improvement.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
