Old 03-12-2013, 11:26 PM   #1
rs74
rs74's Avatar
Will 20 gallon sender work in 16 gallon tank.
I am going to have to buy new tanks after I shorten the frame on my K10. Can I keep the old sending unit from the 20g tank? I will need to see what shape they are in but if they are good then it would be nice to use them instead of buyng new.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 03-13-2013, 02:44 AM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: Will 20 gallon sender work in 16 gallon tank.
Yes.
THe tanks depths are identical. The 16g is just shorter than the 20g tank
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 03-13-2013, 07:33 AM   #3
mrhino
agreed!
mrhino is offline   Reply With Quote
Old 03-13-2013, 08:44 AM   #4
rs74
rs74's Avatar
Originally Posted by BLE 'BURBAN View Post
Yes.
That was my perception but I wanted to make sure. Thanks.
Roy
1987 R10 shortie
Old 03-13-2013, 01:12 PM   #5
bohmankid
bohmankid's Avatar
While on the subject, would a 20 gallon sender work in a 31 gallon suburban tank??
bohmankid is offline   Reply With Quote
Old 03-13-2013, 01:35 PM   #6
83GMCK2500
The fill neck vent line for a 'burban tank is part of the sending unit, waaay different from truck style. Plus, rest of the tubes are facing different directions.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 03-13-2013, 03:01 PM   #7
bohmankid
bohmankid's Avatar
I see, thank you. Is there a difference in sending units for the pre 86 sending units and the 87-91? I know the tanks are different. I'm going to be using a baffled tank for my 5.3 swap.
Old 03-13-2013, 03:07 PM   #8
83GMCK2500
Yes. 87+ units have an electric fuel pump on them for the TBI engines.
Tank openings are all the same, so you *could* technically put an 87+ sending unit/pump into an older tank, but it wouldn't have the baffles. Baffled would be my choice though.
Devin
New Daily, the '96
Old 03-13-2013, 03:23 PM   #9
bohmankid
bohmankid's Avatar
Thanks for the info. after a little research it looks like I'll be buying the 4 tube sending unit for the 87-91 burbans. something like this or this. I'm replacing my fuel pump as well with a high pressure pump for my swap.
Old 03-13-2013, 03:25 PM   #10
83GMCK2500
No problemo. I have an LQ4 on a stand for my truck, one of these days (years), so I've looked into what I need as well.
Devin
New Daily, the '96
Old 03-15-2013, 10:48 PM   #11
kevinr1970
I installed 16 gallon tanks when I converted my CC to a short bed and did nothing else. Everthing works just fine.
On a seperate, but maybe related note, I would like to do a Suburban tank and move my gas door to the Suburban location on my CC.
Any reason this wouldn't work?
I have a parts Suburban with all the parts.
Tired of having to move the truck if I want to fill both tanks!
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
