Old 03-13-2013, 12:37 AM   #1
tgfeller
NV4500 Swap Q's
Currently: 1972 3/4t 4x4 350ci SM465 w/205, 4.11 gears, keeping stock height, frame off resto now
I found a GM 94 NV4500, 5th gear fix, w/ 6.xx 1st gear w/OEM ext. slave bellhousing and 32 spline 241c T-case. ~$850
My driving will be 95% Road/Hwy and 5% off-road. I want a nice DD on snow/ice with occasional N. Idaho light off road.
My questions being:
1. I'd like to save money and use OEM ext. slave bellhousing, can i do it with my use you think?
2. Is the 241 a better choice than 208, I have the option for either
3. Is the older style gear ratio a huge negative for road driving w/ the 350ci? I cannot find a new one to save my life!
4. I'll be going to a hydro clutch can I use the 73+ mc/slave
5. Hows price?
6. Or should I just do a Gear Vendors overdrive for the 465??
I've googled this to death and need just a tad more input on these issues, thanks!!
tgfeller is offline   Reply With Quote
Old 03-13-2013, 09:17 PM   #2
obijuan
Re: NV4500 Swap Q's
My questions being:
5. Hows price?
1. no real clue. i used AA bellhousing.
2. it has an oil pump, 6 gear planetary, and the option to have a slip yoke eliminator. proven reliability with jb conversions.
3. first ratio is negligible. youll probably start off in 2nd anyways.
4. i am using the 85 mc/slave. on my 85 though... originally auto.
5. fair in my neck of the woods.
6. heck no.
one thing i see is that 241 is driver drop. unless youve got plans for a 78-79 ford f250 dana 44/60 up front this will need to be addressed.
also that np241 is VSS speedometer.
only 1989 3/4 ton suburban and standard trans k5 were equipped with a mechanical speedometer passenger drop np241. ive had a couple, but they were harder than normal to find. also id be willing to bet youre gonna want to tire up from stock. especially with 4.10s.
obijuan is offline   Reply With Quote
Old 03-19-2013, 12:56 AM   #3
'63GENIII
'63GENIII's Avatar
Re: NV4500 Swap Q's
I didn't think that Id like the ratio spread of the 94' that's in mine but I've gotten used to it. I'm not sure about mating the 4500 to your 205 though. I think you're going to have to get a different 205. Check out Dirty Larry's threads on this. I personally didn't even want to mess with mating them up. I ended up using a 2wd 4500 and the stock divorced t221. I also picked up a Dodge divorced 205 for 100$. Going to use this if the 221 ever craps out. One of the biggest issues is the stock hyd. BH. I ran it in mine and think I may be lucky. The front driveshaft is @4.5 -5" from the slave cylinder. I don't think they will ever touch but if they do, there are many fixes to remedy it.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
