Guest
Posts: n/a
brake lite still coming on
I just finished changing my rear drum brake shoes, cylinders, the drum itself and hardware. But my Brake lite on the dash still comes on. Why and how do I fix it?
is your brake fluid low? i did nt front brakes and it took about 30 min driving before the light went out
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction). Progress on truck so far (follow link): http://67-72chevytrucks.com/vboard/s...ad.php?t=51051 and stage 2 http://67-72chevytrucks.com/vboard/s...ad.php?t=58132 ~ ![]() ![]() |
Guest
Posts: n/a
then again its always a good thing to bleed the brakes too, too tired and too damn hot:
I hear ya, 95 - 100 deg today, I am getting ready to change out my front calipers, they are gummed up
"Ochre Ogre"
Your dash brake light is still on because the the sensor in the proportioning valve hasn't centered yet. I found in the manual that it says to exert extra pedal presure and it will center and the light will go out. It could also just be full of crud/rust and not want to move like it should.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
To help persuade it to move, have another person apply light pedal pressure, and then crack the brake lines loose one at a time AFTER the prop valve until the light goes out.
69 GMC K10 ..some restoration required....still.. ![]() |
