It followed me home?
another 3/4 to 1/2 conversion ?
So my 3/4 ton has a 14b ff and I am trying to swap to either a 10 or 12 bolt rear. I know the spring perches are located in different widths and I'd rather not change the perch locations on the 1/2 ton axle.
the frame's are the same width right? so I could swap to the 12 bolt by ordering some new front and rear hangers ?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Slots go on anything!
Re: another 3/4 to 1/2 conversion ?
It seems like when I swapped my '75 Blazer to 1 ton diffs, they bolted to the stock springs. That was a long time ago, but I am 100% positeve the only thing I had to do was get bigger u-bolts made.
Why didnt you just buy a 1/2 ton?
"DON'T TOUCH THE TRIM!!"-Early Kyler |
because GM didnt make a 2wd 1/2 ton crew cab short for me. thanks for the help
At the body shop.
One tons are narrower. 3/4 are the same.
Brakes hoses where different up front. Posted via Mobile Device
" That didnt make it any newer " " Dont antique the equipment " |
x2, 10 bolt or 12 bolt will bolt right into your truck.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
I thought they were the same too, the perches on this truck are closer toghether than the 10 bolt I have in my 83 c10
At the body shop.
I cheated when I did the brother n laws crew.
Got 1/2 spindles reamed for 3/4 ball joints. Posted via Mobile Device
#9 | |
EDIT: 6th Digit: 2 = 3/4T, 3 = 1T.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 Last edited by 83GMCK2500; 03-13-2013 at 02:21 PM. |
6th digit is a 2, 1gcgc2...
pin to pin measures 40" w/2.5" leaf springs. So, anyone know if I can use 1/2ton hangers?
At the body shop.
Shocks inside of frame?
Anyways the one i did just bought new spring pads. Seemed easier than changing hangers Posted via Mobile Device
are the 3/4 ton and 1/2 rear axles the same? as in drums and width?
#13 | |
I think it would be much easier to just buy new pads, I may be add a kp 4link/cantilever in a few months and didnt want to have to move the pads again.
#14 |
At the body shop.
One ton hangers. Maybe it depends on the gvwr.
1/2 t shocks are outside the rail as you know. Posted via Mobile Device
#15 |
My conversion was fairly straight forward. I used the complete rear components ( rearend, springs and 1-piece driveshaft) from a donor 1/2 ton and it was a straight bolt in to the original spring hangers. On the front I used a pair of Early Classic Enterprise 3/4 ton 1/2 ton 2 1/2 drop spindles. You retain the stock 3/4 a-arms, ball joints and tie rods,and even the calipers. The only parts from the 1/2 ton I used for the front were the rotors and new pads. Saves a ton of work and I would suggest this option any time. I would have thought I may have had brake issue because of the difference in rear brakes but the brakes are as good if not better than before the conversion. You can check out my build thread titled "Charity Case" and it may have more info. Hope this helps. Oh and to answer the question of why not just buy a 1/2 ton in the first place? As for me, the chances of finding a 1/2 ton with the color, options, and condition that came with my 3/4 ton were slim to none so I grabbed it.
#16 |
your welcome, now point out where in the post you say anything about it being a crew short bed, how was i supposed to know?
#17 | |
Like going to 1/2 ton from 3/4 ton (like I did) or going from Dually to SRW (like I am planning on doing). Some people just get tired of that responce when they are trying to figure something out by asking questions here? It's my truck and i will do what I want with it!!!
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
| Bookmarks |
