Old 03-13-2013, 11:06 AM   #1
1970 C10 MJW
1970 C10 MJW's Avatar
drop question
if I do a 2/3 drop on my 70 will I need to do any other changes? i plan to use drop coil springs to achieve the drop
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 03-13-2013, 02:03 PM   #2
chevyrestoguy
chevyrestoguy's Avatar
Re: drop question
You should be just fine. No other changes required. Do yourself a favor and have the front end re-aligned so your tires won't wear funny.
When you go farther than 4", especially in the rear, you'll need to make some changes, like re-locating the shocks and going to a different track bar set-up. The front depends on how you did the drop (coils, drop spindles/coils, etc) as to what little tricks you'll need to do to make it all work right.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 03-13-2013, 02:18 PM   #3
1970 C10 MJW
Re: drop question
well the front i would use drop coils, and the rear i will use a drop block
Old 03-13-2013, 03:15 PM   #4
Pro Performance
Pro Performance's Avatar
Re: drop question
I would suggest going with a drop coil for the rear, so that the trailing arms aren't hanging down too low and possibly hit the ground if you should get a flat. This also depends on what size wheels you are running.
Pro Performance is offline   Reply With Quote
Old 03-13-2013, 03:36 PM   #5
1970 C10 MJW
Re: drop question
15" by i think 8" chrome wheels kinda like a cragar
Old 03-13-2013, 04:11 PM   #6
CC69Rat
CC69Rat's Avatar
Re: drop question
Possibly leaf springs on the back? I agree with Travis though, If it has factory coils in it now I would just do a drop coil replacement. They are pretty cheap.
Chevelle or 97-06 Jeep TJ springs will bolt into these trucks. Just so you know. The only problem is the spring rates are a lot softer than the truck springs. Yes, it will lower the truck but your ride will be really bouncy / soft. You won't be able to haul much, but .. it's a cheap way to drop the rear of the truck.
.. just sayin
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 03-15-2013, 12:51 PM   #7
1970 C10 MJW
Re: drop question
i dont haul with it much.. but i dont want it to ride like a hoopty lol
