#1 | |
Bloo
changing valve seals without pulling heads?
ive got new rings in my engine, so i know the oil on the plugs isnt coming from the bottem end.... i didnt change the valve seals like i should have though, so how hard would it be to change em without pulling the head?
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
![]() Join Date: Jun 2002
not that hard. apply air to cylinder you want to change seals on(thru spark plug hole)this will keep valve from falling. then use a (on head)valve spring compresser to remove spring, install your new seals and reinstall springs/retainers. Hardest part is leaning over fenders.
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 Last edited by Kid; 06-17-2003 at 02:40 PM. |
CCRider
or if you don't have an air compressor you can stick some rope in the sparkplug hole, then bring the piston up to TDC. [or as far as it will go without forcing it] Gotta know your shade tree tricks.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
#4 | |
Bloo
that sounds interesting on the one about air, i'll have to remember that. the rope one was what i was looking for, i thought i had heard that before
Livin' it up.
![]() Join Date: Nov 2001
yep the rope trick works great. good luck...
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. ![]() |
67-72 Addict!
I just heard this rope trick a few weeks ago but I didn't believe it until now!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
If you decide to replace those stock seals you can also install the "umbrella" type at the same time.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03) 1998 S10 short bed 2002 S10 Blazer 1942 Oldsmobile 1958 Massey Harris Pony 1951 Wife Killingworth, Connecticut May those who love us, love us, any of those who do not love us, may God turn their hearts. And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping. A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist. |
