03-13-2013, 01:47 PM | #1 |
402 BIG BLOCK
Error when using search
Anyone else getting this error when you try and use the search function?
Fatal error: Allowed memory size of 67108864 bytes exhausted (tried to allocate 35 bytes) in /home/admin69/public_html/vboard/search.php on line 1155
1967 C10 swb 1970 GMC Jimmy 4x4 2005 Chevy tahoe Z71 2001 Chevy impala |
03-13-2013, 01:51 PM | #2 |
Re: Error when using search
works fine for me
03-13-2013, 01:55 PM | #3 |
What's the search phrase your using?
03-13-2013, 02:15 PM | #4 |
402 BIG BLOCK
locking rear axle
03-13-2013, 02:30 PM | #5 |
i get that from time to time too.
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 |
03-13-2013, 02:43 PM | #6 |
402 BIG BLOCK
never had a problem before last night, now still problem this morning and afternoon. Hopefully it will work tomorrow..
Anyone want to do that seach and then post the link to it????? locking rear end Trying to get a pic of what the locking rear end from 1970 would look like. Spid label says locking rear end for a option, but it just doesn't look right.
03-13-2013, 02:46 PM | #7 |
Well what do you know, I got the same thing again too!
03-13-2013, 03:04 PM | #8 |
I get that alot too. When it happens I usually just log out for a while and it usually works later when I check back in.
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
03-13-2013, 03:27 PM | #9 |
I, too, occasionally get that. I usually just wait and it resolves itself.
71 K20 64 GMC mud truck |
03-13-2013, 03:42 PM | #10 |
The stock rear for a 70 Blazer is a Chevrolet 3500 AKA 12 bolt. There is no way to identify a posi rear end by a glance as it is the same housing. It may have a tag on a diff. cover bolt. The rear end should have a build number that includes a ratio/application code. If you can find this we can try to look it up. Often it is just easier to pull the cover and inspect the diff.. Most never get the fluid changed often enough.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
03-13-2013, 03:50 PM | #11 |
402 BIG BLOCK
i have the cover off right now.. Anyone got any pics of a 70's locker?
03-13-2013, 04:02 PM | #12 |
here's a pic of my 373 posi from a 71
03-13-2013, 05:09 PM | #13 |
That is a typical Eaton style posi that would have been factory installed. The preload springs are the giveaway. How about a picture of your diff. and the axle code if you can find it?
03-13-2013, 07:07 PM | #14 |
402 BIG BLOCK
No spings on mine, i figured that...
The spid label says positraction, so someone must have changed out the whole axle or just the internals. Anyone know how many teeth would be on a 3.73 ring gear?? spid label doesn't say 3.73 .. hopefully they at least went to a good ratio. The front diff internals look like new, the inside spool inside that holds the ring gear is painted black.. I will post pics shortly or mine.. Thanks guys
03-13-2013, 07:43 PM | #15 |
Just count the teeth and divide. The ring gear might have the tooth counts stamped into it.
03-13-2013, 07:58 PM | #16 |
402 BIG BLOCK
43:13 so 3.08 i guess
Im suprised tgey use this on a 4x4 blazer. This might be slow off the line w 33x12 tires. Hopefully it will help gas mileage. Posted via Mobile Device
03-13-2013, 07:59 PM | #17 |
402 BIG BLOCK
43:14 so 3.08 i guess
Im tgey use this on a 4x4 blazer. This might be slow off the line w 33x12 tires. Hopefully it will help gas mileage. Posted via Mobile Device
03-13-2013, 08:20 PM | #18 |
3.07 gears were standard with a 350 as were E78/15B tires.
03-13-2013, 08:31 PM | #19 |
402 BIG BLOCK
Would 3.07 gears be better than 3.73 gears for gas mileage ?
03-13-2013, 08:52 PM | #20 |
33s should just about kill any chance of mileage you have with 3.07 gears as they make the effective ratio about 2.56. Figure that the stock tires were 26.6" in diameter and your 33s are about 32". So basically you have a tire 5.4" taller and nearly twice as wide plus it is heavier. The only time those gears are helping you are downhill or parked on a grade. You can use a tire gear calculator if you want but the difference is about the same as changing to 3.73 gears. This would give you about the same highway RPM with the 33s as the factory setup was with the E78/15 tires. Now this does not even take into account the extra mass of the wheels and tires. Rule of thumb used to be go to the next lower step after correcting for RPM. So you might actually be happier with 4.11s but 3.73s should give about the best possible mileage IF YOU DO YOUR PART!
03-13-2013, 09:09 PM | #21 |
402 BIG BLOCK
Thanks for the info.. guess ill stick with thw 3.07 for now.
