03-13-2013, 03:16 PM | #1 |
71-72 Gas Pedal Swap Question
I plan to do the 71-72 pedal swap in my 70 C/10. I will be using the LFD mounting bracket along with a 71-72 pedal setup I just picked up and I have a few questions. I figured maybe someone who has done this mod might be able to chime in. Here are some pics with my questions.
03-13-2013, 03:24 PM | #2 |
Re: 71-72 Gas Pedal Swap Question
For the first question, I don't think that should be a problem.
For the second one, I'm not sure. I don't think it'd be a problem, as the nuts are on the firewall, but again I don't know for sure. Third, I believe that makes it so the pedal can't move left and right, because it could get jammed if it does, I honestly don't think I would try it.
71 K20 64 GMC mud truck |
03-13-2013, 04:33 PM | #3 |
Okay here is a pic of mine for comparison with the third pic in my above post.
03-13-2013, 04:34 PM | #4 |
Also, I'm missing the parts numbered in red. I'm assuming this will be an issue too?
03-13-2013, 04:55 PM | #5 |
find a roll pin that'll fit snugly into that spot to keep your petal centered. as for the spring and pin in the diagram I'm curious to see what people say as well cause the setup I bought didn't come with that either!
also for your second question I ground all three posts/spacers flat on mine. so you're fine Posted via Mobile Device |
03-13-2013, 05:24 PM | #6 |
I now see that the return spring and pin are for the pedal (which mine was missing anyway) so never mind that question.
03-13-2013, 06:36 PM | #7 |
fyi I had an order I had just placed with classic parts and I called and had them add the spring and pin to my order. was about four bucks for the pair. wouldn't have known had you not posted the diagram lol. thanks!
03-13-2013, 06:42 PM | #8 |
No problem. Looks like we both learned something today
03-13-2013, 07:03 PM | #9 |
I would love to see a write up with photos on this.
03-13-2013, 07:05 PM | #10 |
http://67-72chevytrucks.com/vboard/s...d.php?t=403451 here's one, check the how to section for more
02-17-2015, 11:48 PM | #11 | |
