Old 03-13-2013, 04:47 PM   #1
thotfulspot
LQ9 power
So I'm planning on putting a LQ9 in my '57 SWB. I was planning on striking, but a couple people have said it's no worth it. So those of you that have done a 6.0 swap, what kind of power do you get stock? How about with L92 heads, a cam, and a LS3 intake? Anyone go all the way with a stroker?
Sorry for asking but wasn't having any luck searching.
thotfulspot is offline   Reply With Quote
Old 03-13-2013, 05:11 PM   #2
tinydb84
tinydb84's Avatar
Re: LQ9 power
Look on the ls1tech forums. You will find tons of info.
I would say go for it. My brother is putting one in his Nova. lq9 with a cam, ported heads, and an intake.
David
Instagram: myfabguy
Old 03-13-2013, 05:38 PM   #3
thotfulspot
Re: LQ9 power
I've been looking at LS1tech and it's tough to find out what parts people are using for rotating assemblies. Most I've seen are around 2K.
Old 03-14-2013, 01:29 AM   #4
Super73
Super73's Avatar
Re: LQ9 power
I have a LS3 block. It has a Callie's crank with Callie's rods and Weisco pistons. It runs ok..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 03-14-2013, 08:51 AM   #5
thump16
thump16's Avatar
Re: LQ9 power
LQ9 is an awesome engine as well as LQ4. I swapped a LQ4 in 84 c10 with no complaints. Don't listen to other people's negative ideas. Try our lsx forum. Plus if it wasn't worth it, why would there be so many LS swaps?
thump16 is offline   Reply With Quote
Old 03-14-2013, 10:28 AM   #6
Billett
Billett's Avatar
Re: LQ9 power
If you are going to stroke it and swap all those parts out just start with an lq4. same basic parts but a decent bit cheaper. Main differences between the two are the dished vs flat pistons which bump up the compression.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 03-14-2013, 10:38 AM   #7
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: LQ9 power
HotRod built an LQ4 with L92/LS3 heads, cam, longtubes, and it made right around 550 at the flywheel.
That's my same basic setup + turbo. Shooting for 700+ rwhp.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 03-14-2013, 01:09 PM   #8
tinydb84
tinydb84's Avatar
Re: LQ9 power
I saw another guy with a cam and ported/decked heads on a lq4 making 450 at the flywheel.
David
Instagram: myfabguy
Old 03-14-2013, 01:20 PM   #9
Wasted Income
Boosted Member
Re: LQ9 power
Sorry, it was car craft, not hotrod.
http://www.carcraft.com/techarticles...ylinder_heads/
Turbo diesel
Old 03-14-2013, 03:10 PM   #10
Hart_Rod
Hart_Rod's Avatar
Re: LQ9 power
How steetable do you think that setup will be? I'm trying to pick a cam for my 6.2 that will have a TVS1900. I'm leaning toward something that will have a somewhat smooth idle and still be able to run a stock converter in my 6L80E. Thoughts?
Hart_Rod is offline   Reply With Quote
Old 03-14-2013, 03:44 PM   #11
thotfulspot
Re: LQ9 power
The LQ4 and LQ6 are the same block. The only difference was the pistons giving the LQ6 a higher compression ratio.
Old 03-14-2013, 04:03 PM   #12
thotfulspot
Re: LQ9 power
Have you driven the 6L80E? I found a low mileage one out of a Camero. Are you using a stand alone controller?
Old 03-14-2013, 04:06 PM   #13
Wasted Income
Boosted Member
Re: LQ9 power
That is a PLENTY streetable setup. I put that exact same cam in an LQ4 that went in my brother's Monte SS. Comp Cams XR281HR, 228/230, .571"/.573" - 112 LSA Has a nice chop to it, and makes good power. It's got a 4L80E with a 3400 stall 9.5" converter in it. Not sure how it would do in a 6L80 with a stock converter?
http://youtu.be/ZU_a24SC6HI
LQ9
Turbo diesel
Old 03-14-2013, 04:08 PM   #14
thotfulspot
Re: LQ9 power
That's what I was considering except keeping the fuel injection with a LS3 intake. If I start with a new block there isn't much difference in cost for the rotating assembly.
Old 03-14-2013, 04:15 PM   #15
Wasted Income
Boosted Member
Re: LQ9 power
http://youtu.be/v2svAR3No1I
This is the LQ4 with the stock 317 heads. Plenty of torque off idle...haha. Shreds the tires at will by just flat footing it off idle...and it's only got a 3.42 gear in it. Granted, the converter helps a bunch....but you should not be lacking any off idle torque with the twin screw.
Turbo diesel
Old 03-14-2013, 05:06 PM   #16
thotfulspot
Re: LQ9 power
LQ9
Sounds nice and seems to have plenty of power. The 6L80 I'm looking at came out of a 2011 Camaro so the converter should be decent. Surprisingly the 6L80 doesn't have a lower first. It splits 3rd an 4th and has an extra overdrive.
Old 03-14-2013, 10:18 PM   #17
Billett
Billett's Avatar
Re: LQ9 power
Actually the 6l80 does have a low first
Gear: 6l80e - 4l80e
First: 4.02 - 2.48
Second: 2.36 - 1.48
Third: 1.53 - 1.00
Fourth: 1.15 - 0.75
Fifth: 0.85 -
Sixth:0.67 -
Will
2024 Toyota Sienna
Old 03-14-2013, 10:21 PM   #18
thotfulspot
Re: LQ9 power
Those are different than I saw. Doesn't really matter. There is no standalone controller. It needs to interface with a Gen IV wiring harness. Huge difference in parts cost if I go the used route.
Old 03-15-2013, 04:03 PM   #19
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: LQ9 power
Gear: 6l80e - 4l80e
First: 4.02 - 2.48
Second: 2.36 - 1.48
Third: 1.53 - 1.00
Fourth: 1.15 - 0.75
Fifth: 0.85 -
Sixth:0.67 -
I love my 4l80e but I want 2 more gears....I think I could be on the freeway at like 900rpm
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-15-2013, 04:08 PM   #20
Billett
Billett's Avatar
Re: LQ9 power
I thought about it for the swap I'm going to do, but I've read that they don't handle the power as well and its 10x more of a pain in the a$$ to connect them.
Will
2024 Toyota Sienna
Old 03-15-2013, 05:02 PM   #21
thotfulspot
Re: LQ9 power
My thoughts exactly. I found one cheap with 15,000 miles out of an 2011 Camaro. Spent the afternoon reading about them. Have to interface with a Gen IV wiring harness and I couldn't find anybody that made a normal shifter for them.
Old 03-15-2013, 05:33 PM   #22
Billett
Billett's Avatar
Re: LQ9 power
If you can find one paired with an l92 it would work just fine but obviously those are a lot.more expensive too. Not to mention it still doesn't handle the power. If you're just looking for MPG though it would be great.
Will
2024 Toyota Sienna
Old 03-15-2013, 05:38 PM   #23
Wasted Income
Boosted Member
Re: LQ9 power
I have a 4L80E because:
1) Cheap as dirt on craigslist or in the boneyard
2) Easy as pie to tune them with EFILive or HPT
3) My 80e with a good converter and minimal mods will handle anything I can throw at it, and get me home again.
Turbo diesel
Old 03-15-2013, 07:23 PM   #24
Jon01
Jon01's Avatar
Re: LQ9 power
Same here. I had a fresh 4L60E and sold it to put a used 4L80E in.
I would not trust a stock 6L80E behind even a mildly built LQx.
That being said, an easy recipe for a 500+fwhp LQ9 is:
799 heads, MS3 cam, F-body accy's, LS6/FAST intake and LT header of your choice.
Jon01 is offline   Reply With Quote
Old 03-16-2013, 12:37 AM   #25
GMC-YA68
GMC-YA68's Avatar
Re: LQ9 power
I put together a striker....it loved a 200 shot!!
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
