Old 03-13-2013, 04:57 PM   #1
72chevynoob
CPP c-notch mounting?
I have the hole cut and the notch lined up, but I bought the notch from a buddy and it did not come with instructions, so I am unsure about a couple things. The main thing is, does the shock crossmember go between the frame and the notch, or outside, and is it a good idea to weld it in and box the frame there?
Justin
69 lwb project: http://67-72chevytrucks.com/vboard/s...d.php?t=558011
72chevynoob is offline   Reply With Quote
Old 03-13-2013, 06:50 PM   #2
sduckworth13
sduckworth13's Avatar
Re: CPP c-notch mounting?
Justin, I just looked at your build and the c-notch install. You did a nice job on the notch, the brace you took out is where your shocks will mount to. You can weld the notch in along with bolting it to the frame also for the extra strength.
Scott
sduckworth13 is offline   Reply With Quote
Old 03-13-2013, 07:35 PM   #3
72chevynoob
Thanks! So does the shock crossmember go under or over the notch? Oor is it up to me? I know stock it was under the frame.
Justin
Old 03-13-2013, 07:50 PM   #4
sduckworth13
No problem, just put the crossmember back to how it was stock.
Scott
Old 03-13-2013, 08:23 PM   #5
72chevynoob
Makes sense. I will do that. Thanks for helping me out!
Justin
Old 03-13-2013, 08:28 PM   #6
sduckworth13
Your welcome
Scott
Old 03-13-2013, 10:05 PM   #7
Andy4639
Old member
Andy4639's Avatar
Wink Re: CPP c-notch mounting?
Something to think about while you have it out. U want the shock to be almost straight up and down when done. I would suggest the No limit shock relocator. I bought it for my 71 and the truck rides great.
Are make you a set if you can cut and weld.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-13-2013, 11:51 PM   #8
72chevynoob
I have been drooling over that kit for a while, unfortunately shipping woulbe crazy so I will probably make my own. They may stay inboard of the frame, however.
Justin
Old 05-28-2013, 09:44 PM   #9
jondancer
So does the notch mount over the crossmember at the spring mount? Looks like its going to need some trimming ..
jondancer is offline   Reply With Quote
Old 05-28-2013, 09:53 PM   #10
72chevynoob
The crossmember is supposed to mount over, so some trimming would be required. I ended up building a custom crossmember anyways, so it doesn't matter. I'm sure it would be fine either way, though. 3/16" really isn't that big of a deal, especially if you want to strengthen the notch by welding it in.
Justin
