Old 03-13-2013, 06:40 PM   #1
byates2
byates2's Avatar
Tach Filter
The tach filter wires are a much smaller wire than the actual harness for the tach. If i put the filter in line will that pose a problem as the smaller wires may heat too much? Does the tach harness get that much electrical current through it to make those smaller wires on the tach filter heat??
1967 C10 Long Bed, Soon to have a 350
1997 Chevy 2500 454 BB
byates2 is offline   Reply With Quote
Old 03-15-2013, 02:55 PM   #2
byates2
byates2's Avatar
Re: Tach Filter
Anybody have any advice
Old 03-15-2013, 05:09 PM   #3
john
member #16
john's Avatar
Re: Tach Filter
What kind of tach.? I have a aftermarket factory type that woks good and does not use a filter. Also have HEI dist.
john is offline   Reply With Quote
Old 03-15-2013, 07:34 PM   #4
byates2
byates2's Avatar
Re: Tach Filter
It's a repro of the original. They say on the website you need a filter with hei
Old 03-15-2013, 09:02 PM   #5
ray_mcavoy
Re: Tach Filter
On the original GM tachs, the filter was only used to prevent interference with the radio. I've hooked original tachs up to HEI distributors without a filter and haven't had any problems. But if the manufacturer of the reproduction tach says to use a filter it would definitely be a good idea.
There is very little current flowing through the tach signal wire. So the smaller gauge wire on the filter shouldn't be a problem at all. I fact, the only reason I can think of for GM to have used such a heavy gauge wire on the factory tach harness was for durability. Even the +12V power wire is oversized for the amount of current drawn by the tach.
ray_mcavoy is offline   Reply With Quote
