72ChevyStep
![]() Join Date: Jun 2009
Automatic Brake Pedal Assembly
Automatic Brake Pedal Assembly removed from a 1971 C-10. $45 shipped.
![]() Join Date: Apr 2011
Re: Automatic Brake Pedal Assembly
I have a 67 that is currently a standard. I am doing an auto swap. Any idea if this will work?
![]() Join Date: Oct 2006
72ChevyStep
It should work, as long as the mounting holes in the 67 Cab firewall aligns with the master power booster in the engine compartment. BTW: The Power Brake Boosters are made for 67-72's so my quess is yes, it will work.
I just unbolted the clutch pedal. This is more for those that are totally missing a pedal.
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
Has the arm been cut and welded?
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
72ChevyStep
Yes, the assembly is modified. Sure makes it easier for your foot to find the brake pedal, so if you have long legs, its the perfect setup and its not that noticeable when installed. If interested, let me know.
72ChevyStep
ttt
I also have a '71 that I am upgrading to power brakes from manual. Will I need to replace the current pedal assembly with one like this unit?
Thanks! -Ed |
72ChevyStep
Long time ago, but has this sold?
68 SWB 5.3 turbo build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578220 |
