06-17-2003, 04:52 PM | #1 |
Whats the difference?
Could someone tell me the difference between I6 motor towers and the sbc towers.
Thanks Mario
1967 Chevy SWB |
06-17-2003, 06:48 PM | #2 |
Progress = 0%
I can't explain the actual physical differences, but the sbc towers mount in the forward set of holes on the frame/cross member and the I6 towers mount in the rear set of holes. However, you can mount the sbc on the I6 towers in the rear set of holes. Make any sense?
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
06-17-2003, 07:09 PM | #3 |
Fabricate till you "puke"
The I 6 towers will set your sb 3 1/2" rearward from factory location (plus or minus 1/8"). Good for weight transfer, but a little tight on HEI clearance. I have done 3 trucks with sb ,on the 6/250 towers......IMO, the factory should have done it that way. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
06-18-2003, 02:06 PM | #4 |
Mario
1967 Chevy SWB |
