Old 03-14-2013, 12:38 AM   #1
BadaSs_Cal
BadaSs_Cal's Avatar
¿¿¿Weird Light Question???
First time drove the truck out of the yard today. I was worried because ( what I believed was a bad Blinker switch in the column) was messing with the brakes. If its in the Left blinker position only the Left break will go on with the break pressed in. And right position is only right break light.
So I just figured bad switch, or my wiring is screwed up.
Well then it got dark, so I tried my luck with the markers and they work fine. And so does everything else. The blinkers, brakes, everything functions like normal.
So what the heck?
What would make that happen?
Im using those universal 2 wire lights round lights you see on everything from old stepsides, and trailers.
66 Gmc 1 ton. Long Step 351e V6
69 1/2 CHEVROLET (now a shortbed) LONGBED!:devil
61 Shortbed Fleetside 1/2 ton.. in progress
Next a 50-53!
MY BUILD THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=447926
BadaSs_Cal is offline   Reply With Quote
Old 03-14-2013, 03:21 AM   #2
old cruiser
old cruiser's Avatar
Re: ¿¿¿Weird Light Question???
My first check is always the ground wires the ground or earth wire depending on where you're from is normally the biggest cause of electrical issues
old cruiser is offline   Reply With Quote
Old 03-14-2013, 06:26 AM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Check the ground on the tail lights.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
