Old 03-14-2013, 02:14 AM   #1
EricElle
1963 Glove box (need pictures!)
So all I had from the PO was a glove box door, I just received and installed the inner cardboard and striker plate from classicparts.com. I cant seem to find any info on how the actual door is installed and I dont have the brackets that I believe are needed to complete this. Just need a few pictures as reference to make sure Im doing this right. I'd also like to know if I need the specific bolts and spacer that the door is attatched to (I'm missing one), thanks!
Could also post pics of mine as it is at this moment, if needed.
EricElle is offline   Reply With Quote
Old 03-14-2013, 03:51 PM   #2
PAPA KENT
PAPA KENT's Avatar
Re: 1963 Glove box (need pictures!)
you will have 2 brackets that mount as pictured,the bottom of the brackets have holes where the spacers ride then of course your bolts screw into the door itself.
good luck!
PAPA KENT is offline   Reply With Quote
Old 03-14-2013, 03:54 PM   #3
PAPA KENT
PAPA KENT's Avatar
good luck!
i forgot the pictures,here ya go.
Old 03-14-2013, 04:23 PM   #4
EricElle
good luck!
Wow thank you! This helped a lot, all i need now are the brackets and spacers.
Old 03-14-2013, 05:59 PM   #5
PAPA KENT
PAPA KENT's Avatar
your welcome.
