Old 03-14-2013, 12:08 PM   #1
heathbirkendahl
GM ZZ4 Crate Engine
Hello Everyone!
Anyone put one of these in their truck? (dumb question probably)
I'm ordering it today and want to do one last gut check to make sure there was no gotcha's!
Thank you!
HB
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline   Reply With Quote
Old 03-14-2013, 12:40 PM   #2
1972SUPERSB
1972SUPERSB's Avatar
Re: GM ZZ4 Crate Engine
I had one in my 84 short bed. You will love this engine. Great power. Aluminum heads. Engine runs very strong. I have no regrets after buying this engine. You need to get the d port headers and a hi torque starter becuase of the hi compression
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 03-14-2013, 12:48 PM   #3
heathbirkendahl
Awesome! I'm 1/2 way there with the dport. And my starter is blasted. LOL
Old 03-14-2013, 01:32 PM   #4
1972SUPERSB
I had the hedman headers and regular starter. The started worked for a while then started to slow down. That's when I got the hi torque starter. I bought my engine at pace performance. This was about 10 years ago
Jeff
Old 03-14-2013, 02:02 PM   #5
Chief29
High torque starters are the way to go. Heathbirkendahl be fore you order have you looked in the all the GM crate engines? Cause for the same price (depends where you get it) the "604" engine is the same price and more HP lowr compression for pump gas same heads bigger intake valve and an open plentum intake also the cam is the same. They run these engines in dirt late models here in Indiana and on some night the out run the 800hp engines. Just wanted to share that with ya and they have the same camshaft aswell.
Chief29 is offline   Reply With Quote
Old 03-14-2013, 02:24 PM   #6
Tim Christian
Tim Christian's Avatar
I bought one with they first came out. They are a excellent motor. Put mid length headers on it from Street and Proformance. But i disagree with everyone on the Hi-Torque mini starters. I tried 3 diffrent brands and they are all JUNK. I just bought a brand new full size starter from my GM Dealer installed it a five years later still not the first problem.
Tim Christian is offline   Reply With Quote
Old 03-14-2013, 06:13 PM   #7
heathbirkendahl
Thanks everyone this is all great info. Keep it coming.
I have shorty headers already but will need a starter. I will look at the dealer as well.
Old 03-14-2013, 11:09 PM   #8
70blackfish
how much are these engines? where you going to order it from?
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 03-14-2013, 11:41 PM   #9
HotRod C/10
HotRod C/10's Avatar
jegs has them
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 03-14-2013, 11:51 PM   #10
67_ShortFleet
67_ShortFleet's Avatar
Subscribed for the info!
Matt
Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784
My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924
My philosophy on tires is the same as cigarettes. "smoke them if you got them"
HAPPILY DIVORCED!
67_ShortFleet is offline   Reply With Quote
Old 03-14-2013, 11:54 PM   #11
1972SUPERSB
I paid $3500 10 years ago. Now I think they are around $4200
Jeff
Old 03-15-2013, 12:20 AM   #12
Z10
Z10's Avatar
I purchased one about 2 months ago. I'm in the process of prepping it for installation. 700R4 came in last week, Sanderson ceramic headers, on the way. I purchased mine from a dealer in Nebraska for about $5,200 with free freight. Complete carb to pan and serpentine system. I have the same engine in my 69 Camaro and love it. Still need to add the aluminum pan pics.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 03-15-2013, 01:14 AM   #13
dan42
dan42's Avatar
I have one in my pickup as well. Very nice motor that likes to be driven hard, and there is a lot of info on the Internet about them. One thing that is annoying about them is that they are pretty noisy motors - a lots of valve/ lifter noise, like you haven't changed the oil in a while. I got mine from jegs and they 1) sent it unstrapped on a pallet, and it rolled around, crushing the oil pan; sent a distributor that was all jacked up; missplaced parts for the air filter; sent a bad starter, and the flex plate was bent, and since I am running a manual, had to switch out with a flywheel. Other than that, jegs did a great job.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 03-15-2013, 01:25 AM   #14
Z10
Z10's Avatar
Wow, mine was perfect. strapped to a wooden engine stand, then to a pallet, covered with a heavy cardboard box. Carb, distributor, starter, serpentine, alternator, a/c compressor, bolt kits, wires, etc were all packaged separately.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 03-15-2013, 09:01 AM   #15
Chief29
Jegs has free shipping on ALL GM engines that's what there website says anyway. The only thing about the 604 that I said is the same is that you will have to take the seals out of the engine at the dealer or if you know someone to take them out and replace them with regular engine fasteners.
Old 03-15-2013, 10:13 AM   #16
dan42
dan42's Avatar
Jegs took care of all the problems, but it shouldn't have been that way in the first place. Another guy I the shop had a big block Ford motor ordered from Jegs and had similar problems in terms of missing parts. I still order stuff from them and I might even order s motor from them but as soon as you get it, check it out thoroughly, and if its not right, call them and send it back. They are pretty good about that part.
Philippians 4: 6-7
Old 03-15-2013, 11:11 AM   #17
Tim Christian
Wow i cannot beleive how much they went up. I bought mine right when they first came out to replace the ZZ3 and got it for $2995.00 + $100.00 to ship.
Old 03-15-2013, 03:46 PM   #18
Z10
Z10's Avatar
Friesen Chevrolet in Sutton, NE. They were actually a couple hundred less than the big guys and free freight. You might have to ask them to match the free freight.
Could have bought it closer but avoided sales tax using an out of state supplier. Which would have been about $400.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 03-21-2013, 11:07 AM   #19
heathbirkendahl
I could of saved $300.00 or so by getting it from Summit or Jegs. BUT... the warranty they give is not as good as the dealers. So I went with the dealer. It should be here next week and then the project begins.
Old 03-21-2013, 07:54 PM   #20
mrh33916
Project '67 454
mrh33916's Avatar
The starter from a '93-'96 V8 Camaro and a '94-'96 Caprice LT1 is a factory gear reduction starter that was used with the 153 tooth flywheel. I've had one from the junk yard on my ZZ4 for 12 years now.
It cranks every time.
I agree, stay with the factory GM starters
67 C-10 SWB Fleetside 454 (current project)
99 Crewcab SWB Dually 454
75 Datsun 280ZZ430
94 Formula 232LS 454
mrh33916 is offline   Reply With Quote
Old 03-21-2013, 08:06 PM   #21
heathbirkendahl
I got that exact starter from the dealer with the motor. Thanks for the confirmation.
