03-14-2013, 01:20 PM | #1 |
Short vs Long Water pump for SBC ??
I have a 1967' C10, and I am doing SBC conversion from inline 6, to SBC 350.
What is the reasoning for a Short vs Long water pump?
1967 Chevy C10 Lwb I6-250ci 3spd manual trans Future Projects, Power Brakes, Front Discs, Power Steering, Paint Frame, New 350ci engine Bored .040 357ci Magnum, Vortec Heads, Comp XE262 Cam, Performer EPS Intake, 650CFM Carb, Rebuilt Trans 700r4, 2000-rpm stall, Completely Rebuild & Upgrade Front & Rear Suspension & Steering Components, Suspension Drop 3.5" & 5" Drop, 1.250 Sway bar, |
03-14-2013, 01:27 PM | #2 |
Rusty Nuts
Re: Short vs Long Water pump for SBC ??
If i am not mistaken it depends on alternator brakets and power sterring and pullies, things like that for the water pump to line up but i might be way off base here, some one else here will know for sure though.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
03-14-2013, 01:28 PM | #3 |
No idea. But gm used the short on trucks up to 72 and long on 73+ trucks. You can use either but beware! Each has different brackets/pulleys for everything! So use whatever pump you have all the brackets/pulleys for. Trust me, swapping from one to the other can get expensive fast. I used a 350 out of a mid 70s truck and had ps and ac for short set up so had to track down/buy all the correct pulleys/brackets for the other stuff.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
03-14-2013, 01:36 PM | #4 |
If you are not worried about being period correct, go with the long water pump. Brackets and accessories are MUCH easier to find, including serpentine setups if you eventually go that route.
1971 C20 "Shreck" 1980 C30 dump bed "Ratchett" |
03-14-2013, 01:53 PM | #5 |
So based on my Pulley & bracket set up.
All that I have currently is still on the Inline 6, engine, is there any chance that those would work?
03-14-2013, 02:01 PM | #6 |
It's been a while, but the Water Pump pulley may work. I would go with a SWP set-up. It will look correct and all components could be swapped to any future SBC swap.
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
03-14-2013, 02:42 PM | #7 |
Sounds like it's time for a junkyard run to pull everything you need off another 350. I don't think much if anything tranfers from I6 to sbc. I bought a 100% complete blown pontiac 350 because I had no parts at all for my pontiac motor. Paid $250 for complete 69 subframe/motor (I needed subframe too). I'm going to save a ton with everything I got.
03-14-2013, 03:14 PM | #8 |
I used the long pump on mine bought a billet w/p pulley and crank pulley and everything else was stock and works fine
03-14-2013, 03:16 PM | #9 |
Since you are swapping from a 6 to a v8, you can place the engine in the big block location, use a serpentine kit (long water pump) with fan and all with a big block shroud. You have to redo the exhaust and everything anyways, so setting the engine back an inch or 2 from the standard small block location won't be a big deal. Another thing, if you can find some big block stands you could also use some later model exhaust manifolds, unless you plan on headers
03-14-2013, 04:46 PM | #10 |
As stated before..long water pump brackets are easier to find in the boneyards. Chevy cars like camaro , chevelle ,full size chevs all used the long pump from 1969 up...big blocks were different though.
