Old 03-14-2013, 03:08 PM   #1
kwmech
Serpentine big block belt kit
With a twist, I've been searching and cannot find quite what I would like. I'm gonna be doing a big block swap into my flatbed (hopefully) this summer. I DO NOT like the electric fan set-up as I've had problems in the past with overheating. That being said, SHORT water pump serpentine, that keeps the alt and ac on there respective sides in the compartment. Anybody done this? custom? made it yourself?
Old 03-14-2013, 11:42 PM   #2
67ctener
67ctener's Avatar
Re: Serpentine big block belt kit
I'm in the same boat but decided to go with billet specialties independent brackets for short pump keeps ps and alt on driver side
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 03-14-2013, 11:43 PM   #3
67ctener
67ctener's Avatar
It is v belt though, only have seen serp. Systems in long pump
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
Old 03-14-2013, 11:54 PM   #4
buckskins4ever
buckskins4ever's Avatar
Just a curious question about your issue with electric fans. When you have run them in the past have you put on a adjustable temp relay switch?? I have been running them for several years on everything from a small 305 to 454 and even in the new 6.0 swap we did in an impala recently. always dependable, and reduces drag on motor. The switch usually runs between $25-$60 depending where and what brand.
buckskins4ever is offline   Reply With Quote
Old 03-14-2013, 11:55 PM   #5
buckskins4ever
both March and Billet Specialties only make serpentine systems for long pumps that are a conversion kit. Most are going to be v-belt.
Old 03-19-2013, 02:06 PM   #6
kwmech
I've run the adjustable switch, it just wouldn't cool the big block in my tow truck, fans were running constantly trying to keep up. Regardless, looks like I can use some of the March stuff and fabricate my own Alt and AC brackets to tuck them in. Couple of companies make a reverse rotation water pump, I may start from there.
Old 03-19-2013, 02:13 PM   #7
jeh
jeh's Avatar
I got a factory style GM Perf. at Summit Racing, it included everything ( water pump, alt., power steering pump, ac comp., and all brackets). I don't have the truck on the road yet, so I can't give any feedback. It is a serpentine.
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 03-19-2013, 02:22 PM   #8
kwmech
I am wanting a SHORT water pump system
