Old 03-14-2013, 03:19 PM   #1
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
CONFIDENTIAL 1963 Chevy Vs. Ford.
Old 03-14-2013, 03:21 PM   #2
Reyals Bemus
Re: CONFIDENTIAL 1963 Chevy Vs. Ford.
That's amazing!
Reyals Bemus is offline   Reply With Quote
Old 03-14-2013, 03:34 PM   #3
PAPA KENT
PAPA KENT's Avatar
COOL! keep them coming.
PAPA KENT is offline   Reply With Quote
Old 03-14-2013, 03:37 PM   #4
Greg63
Enjoy your truck
Greg63's Avatar
I am definately going to be buying a Chevrolet after reading that.
$16.75 to upgrade to an alternator from a generator at Ford - what are they thinking over there? ;o)
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 03-14-2013, 07:12 PM   #5
factorystock
factorystock's Avatar
As a student of historical truck facts, yes Chevy did have the edge in '63. '63 Ford and Dodge pickups were similar to 59 Chevy trucks. It took till '65 for Ford to have a more competitive product. One note though, Chevy did not a have a fully syncronized 3 speed in their trucks, a major shortcoming especially in an era when most 1/2 tons were sold with 3 speeds. 63-66 Ford pickups came with full syncro 3 speeds.
factorystock is offline   Reply With Quote
Old 03-14-2013, 07:57 PM   #6
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Amazing info you have !
Now I believe you when you said you were asked by a women for a 69, you replied "sorry, I only do 63's"
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 03-14-2013, 11:01 PM   #7
chevyrestoguy
chevyrestoguy's Avatar
Ford's biggest vice was they they stayed with the straight axle for too long, and when they finally changed it, they came out with the crappy Twin I-Beam. GM proved early-on that the independent front end was the way to go.
Ford made excellent rear axles (the 9"), but their front suspensions were horrible.
Plus, if you compare a '60s GM truck and a Ford cab, the GM product is double-walled in a lot more places than the Ford. Ford came out with their new design in '67, and it was actually a pretty tough truck, with the exception of the front suspension.
I will say that whoever designed the '67-93 Ford truck door latches did an excellent job. You can go to any clapped out Ford in the wrecking yard and the doors shut beautifully on those things. Very nice engineering.
But, if you own a Ford, you had better know the month it was made, because when you have to order parts for it, you will find out that Ford constantly changed their designs. Who else would make THREE different 351 engines (the Windsor, Cleveland, and the Midland) and hardly anything interchanges between them? Who else would make a 427, a 428, and a 429, all within a 7 year span? Who else would make a C4 transmission with either a large or a small bellhousing, depending on the engine? Who else would design an engine (351 Cleveland) where the cam journals received oil before the crankshaft did?
GM absolutely out-engineered Ford on every level in the '60s.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 03-15-2013, 01:55 PM   #8
1963c-10
1963c-10's Avatar
Yeah, but who needs a synchronized 3 speed when you can double clutch it and drop it into 1st.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
