03-14-2013, 03:23 PM | #1 |
6cyl Power Steering Pulley
I have an extra power steering pulley for a 6cyl 250 setup. Part Number 3791943 GM
This fits the early "correct style" power steering for these trucks and was removed I believe from a 68 Camaro. Its been sand blasted and painted with Satin Black epoxy. Has some nicks and such and the back side has some pitting. I actuallly paid $70 for this before I blasted and painted it. Will take $50 shipped CONUS |
03-14-2013, 07:07 PM | #2 |
Re: 6cyl Power Steering Pulley
What do you mean "correct"? I noticed when I put my p/s on that my pulley is slightly out of alignment with the rest of the pulleys. Will this pulley correct that condition?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
03-15-2013, 05:13 PM | #3 |
The 6 Cyl and 8 Cyl Pulleys are different. If you are using an 8cyl pulley, that could be the reason it is off. I have one of these pulley numbers on my truck and alignment is spot on. Ill post a pic of the setup that this is correct for.
03-15-2013, 05:16 PM | #4 |
Fits this setup. |
03-16-2013, 07:26 AM | #5 |
I will have to check the p/n on my pulley. I am also running the later "square reservoir" pump. Do you know if those pumps have a different shaft length?
03-16-2013, 10:17 AM | #6 |
I will get in line for this if you will ship to Canada. This is also correct for 67 327 with power steering.
03-16-2013, 11:38 AM | #7 |
The later style that you have uses a different pulley. Actually with that setup I do believe that you have to utilize the Crank and Waterpump pulleys that went with it. That is more likely your issue.
03-16-2013, 11:39 AM | #8 |
03-16-2013, 03:13 PM | #9 |
03-16-2013, 06:56 PM | #10 |
I will pass this to someone else. Thanks for getting me the quote. Rod.
03-17-2013, 10:07 AM | #11 |
Ok, thanks for your help.
03-19-2013, 07:15 PM | #12 |
Ttt
03-29-2013, 08:51 PM | #13 |
ttt
04-26-2013, 08:03 AM | #14 |
Is this still for sale? Would you do $45 shipped?
04-26-2013, 08:28 AM | #15 |
04-26-2013, 08:38 AM | #16 |
Payal sent. If possible, please ship right away. I miss my power steering. I bought a replacement pump, and I did not realize there were two shaft styles. Wouldn't you know, I have the press-on style and the replacment pump is the bolt-on style. If you have the nut, I could use that too.
Thanks, Mark
04-26-2013, 08:39 AM | #17 |
PM sent with shipping address.
