Old 03-14-2013, 03:29 PM   #1
mjensen
mjensen's Avatar
Brake bulkhead fittings
I posted this in suspension, but didn't get much response. Hoping someone here could give some guidance.
Why is it so difficult to find bulkhead fittings to route the brake lines through the frame? I know there are a ton of options if you want to run AN and adapters, but really I'm just looking at replacing my stock setup because I lost the originals. Maybe I'm not using the correct search terms? If anyone has an idea, or some direction, I would greatly appreciate it!
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 03-14-2013, 04:36 PM   #2
cdowns
cdowns's Avatar
Re: Brake bulkhead fittings
speedway motors has loads of stuff for people that fabricate stuff like brake systems
Old 03-14-2013, 04:38 PM   #3
mjensen
mjensen's Avatar
I have seen their stuff, but I was hoping to stick with the double-flare stock stuff instead of having to adapt AN fittings. I may have to go that route though if I can't find stock.
I guess I could just junkyard dive too.
Mike
Old 03-14-2013, 05:17 PM   #4
JointTech
JointTech's Avatar
speaking of bulkheads... check fastenal.com. i just ordered some for a different project but noticed they have a DOT section for brake stuff. Lots of bulkheads there. I got brass ones for my project. Just got an email saying they are being shipped to a central warehouse from all over and then to me. bleh. slow. glad i didnt waste any money on overnight shipping.
http://www.fastenal.com/web/products...l.ex?sku=67885
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 03-14-2013, 05:23 PM   #5
mjensen
mjensen's Avatar
You know...I found that, but the 1/8" MPT through me off. I figured it must be different that NPT, but then when you read in the details it states NPT. One question/concern I have is that it states it's for air brake applications with a working pressure of 125 psi. Doesn't a modern braking system run about 1200 psi? I thought I read that somewhere, but I know I'm crazy
Mike
Old 03-14-2013, 05:26 PM   #6
JointTech
JointTech's Avatar
keep looking. i saw stuff that was 2000psi im pretty sure.
To answer your question I have no idea on the mpt/ npt/ compression thing. that crap all confuses me and I always have to bring one with me and fiddle till i find one. I took a chance on this order so we will see if my npts and mnpts fit haha
also no idea on brake psis.
72 C20 Long Bed
Old 03-14-2013, 05:29 PM   #7
mjensen
mjensen's Avatar
Okay, I'll keep looking. You'll have to let me know how it goes for you.
Mike
Old 03-15-2013, 11:37 AM   #8
Boat211
I have been looking for the same items. Ill keep an eye on this thread.
Boat211 is offline   Reply With Quote
Old 03-15-2013, 05:04 PM   #9
john
member #16
john's Avatar
I don't think these trucks used inverted flare bulkhead fittings originally. Mine doesn't have any. All i can find are AN bulkhead fittings. Possibly you can adapt to them.
john is offline   Reply With Quote
Old 03-15-2013, 05:16 PM   #10
mjensen
mjensen's Avatar
I think I'm making stuff up lolife99 (thanks!!!) responded to my other post (I know sorry I was desparate for an answer so I have two posts on this). He informed me that the hose would go through the hole in my frame and attach directly to the T on the hard brake line. There wasn't a bulkhead fitting for the front.
Here's a pic of what I HAD :-( and it seems to make sense.
Mike
Old 03-15-2013, 06:34 PM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
All the steel brake line fittings are inverted flare.
At the M/C, at all the line connections and at the wheel cylinders.
Keith
Convert to disc brakes.
Old 03-15-2013, 07:10 PM   #12
john
member #16
john's Avatar
Referring to the bulkhead fittings. Thanks
