Life is Good !
Fuel mileage question
After reading a few differant post on fuel mileage. I wanted to know what kind of mileage Jenna's 71 was getting? So I started to keep track of the fuel and mileage. The only thing is I have never tryed or had to figure out what the fuel mileage is. could someone show me how? Here is the #'s I have.
12.2 gallons 15730 mileage 13.5 gallons 15908 mileage 11.8 gallons 16047 mileage 11.5 gallons 16191 mileage I have been trying to keep track but the wife fills up and forgets to write down the mileage. ![]() ![]()
'72 Chevy C10 4x4 shortbed "Project" '71 Chevy C10 2wd longbed "partsrunner" '91 Chevy Burb 4x4 "kidrunner" '14 Honda Accord Sport "commuter" |
Glowing since 1978
I assume that you filled the gas tank to full at each stop for gas. I took the total mileage traveled which would be 16191-15730=461 miles and it took 13.5+11.8+11.5=36.8 gallons of gas. So divide the miles/gallons and you get 12.52miles/gallon. You have to leave out the first 12.2 gallons because that just got you to the reference full mark on your gas tank to start determining miles per gallon.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
CCRider
You got 13.1, 11.7, 12.5 for an average of 12.4. Just divide miles traveled by gallons used.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
9.4mpg? am i correct?
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
shouldnt it be 461miles divided by49gal?
Life is Good !
ddsmith and tom hand, thank you for the input. I guess it is time to get out and do something to get the fuel milage up.
Glowing since 1978
crazy4chevs you have to leave out the first 12.2 gallons because that just got you to the reference full mark on your gas tank to start determining miles per gallon.
its all about the +6 inches
12.5 MPG if that is combined city/hwy...that isn't too awfull bad.
While some combos (even some stock ones) can get quite a bit more, most are lucky to bet past 10 or 11 (again...even stock). This even includes the inline engines. |
Fabricate till you "puke"
I think the Richmond overdrive upped me to about 10 mpg vs the 8.5 the 400 t/2400 stall verter was giving me......toys are fun, but not cheap! Im not too sure on your gearing(maybe missed it, kinda blind!). At anyrate, if that 1/2 ton truck is running 3.73 gears, the milage doesnt sound too bad. I had a very mild 327, witha 4spd(passenger), with 3.73 gears. The truck would get 12 mpg on the road running 60-62 mph.....it would pull a freakin mountain tho! not too bad a trade off in my book
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Formerly yellow72custom
12.5 is about what it should get, that is what i get on the highway, with a lead foot. Around town i get about 11mpg.
What are the specs on the motor? If it dosen't already have them, add a HEI distributor, some free flowing dual exhaust, and if you want too add a set of headers. It would also have more power with those upgrades.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
Dang, congrats on your gas mileage. I have a 95 4x4 chevy that barely gets 15mpg. My 72 gets about 4 gallons to the mile, at least that is what it seems. I agree with crazy longhorn, our toys are extremely fun but definitely not cheap.
BTW Tom Hand is correct on the mileage calculations.
http://photos.yahoo.com/cruzn72@pacbell.net |
