Old 03-14-2013, 08:19 PM   #1
wibilly
wibilly's Avatar
transmission options/ gearing
Been awhile since i've popped in but i'm thinking about playing truck again.i don't think i put 50 miles on 2 trucks combined last summer. thats not gonna happen this year.any body running a np 883 in there trucks and if so how do you like the gearing?my 69 is like a tractor now with the 4 speed and 410 final drive.3rd gear in 3 feet with a car on the trailer and looking for another gear at 35 mph with 31x10.50s on her. not to mention she has a drinking problem, 12 mpg at 70. not sure if i wanna go to a set of 308s or put in an od trans or 373s and od i have a 883 but never driven atruck with one hate togive up that 3rd peddel. just wondering if anyone else made this swap and if so was it somthing you would recomend. i already havve every thing for trans and rear end swap just wondering what way to go. thanks for any help you can be
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-14-2013, 08:37 PM   #2
SS Tim
SS Tim's Avatar
Re: transmission options/ gearing
To me a lot depends on how you use the truck and what you have for a truck. Four speed and 4.10 does not tell me much. But 12mpg at 70 is not too bad in itself.
SS Tim is offline   Reply With Quote
Old 03-14-2013, 09:57 PM   #3
wibilly
wibilly's Avatar
it's a 69 with a 80 350 i use it forwhatever i need a truck for and daily driver i tow my race cars and sawmill and bobcat at 55 towing my race car it will do 14 mpg but that is not acceptable when it is a minimum of 50 miles anywhere it is over 120 miles to the track i guess i should just sell all the junk and get a geo
Old 03-14-2013, 10:26 PM   #4
SS Tim
SS Tim's Avatar
OK lets try this again. If it is a C10 or K10 you are beating it up. If it is a C20/30 that is not bad. If it is a K20 that is really not bad mileage. In any case an O/D 883 is a fairly light duty trans. and the GM versions (IIRC MY6?) seem tough to find. Towing loads like you are talking brings me back to my favorite, a Gear Vendors O/D. It will turn your 4 speed into a very useable 7 speed. It basically will give a halfway split between gears and a O/D for freeway running. They can often be found used at reasonable prices.
http://gearvendors.com/cg2wdt.html
Old 03-15-2013, 12:55 AM   #5
wibilly
wibilly's Avatar
thanks for the response Tim. A gearvenders od would be the cats a$$ but i don't have one of them laying around, i do have the 883 and i do hav 60 plus trucks to choose rear gears. do you know the od ratio for the 883.i would gladly give up my granny gear for the od but i could also swap out the rear end alot quicker and easier and get a posi too
Old 03-15-2013, 01:30 AM   #6
SS Tim
SS Tim's Avatar
The RPO MY6/NP260 is the same ratio as the A-883 Chrysler trans.. They are not interchangable and it does not have the iron case of old. At one time after a lot of research on these I finally concluded it was not for me. As posted before it is not a HD trans..
Keep your eyes open on CL as Gear Vendors units pop up all the time. There was a Chevy truck four speed with a G/V unit earlier this year in the SF bay area for a $1000. Last fall I found a running crewcab dually TH400 with a G/V overdrive in LV, NV for $1500. Should have bought that one to part.
However to see details with your own eyes here is a 2009 article from my links folder.
http://www.customclassictrucks.com/t...n/viewall.html
http://www.vibratesoftware.com/html_...ons.htm#4sptrn
Last edited by SS Tim; 03-15-2013 at 01:38 AM. Reason: If you didn't see it I'm not telling
