03-14-2013, 10:30 PM | #1 |
That's it I'm done
I'm going to buy new upper and lower control arms, it's just now worth it. These things are a PITA to just get one free and I still have 3 more. Just wish I knew this before I bought new ball joints and bushings
oh well who do you use for new control arms? |
03-14-2013, 10:44 PM | #2 |
Re: That's it I'm done
Here is the demon Posted via Mobile Device |
03-14-2013, 11:20 PM | #3 |
The Peacemaker
If you want completely new, I would suggest DJM/Calmax for a static drop.
http://djmsuspension.com/application...letgmc/c-kits/ If you want nice used ones....now that I am done with school for a little bit and it is warmer I have some dropped a-arms on my 82 k5 2wd Blazer that I will be removing. Don't know your time frame though.
1978 Chevy 2wd Stepside aka "Audrey" Cordova brown with mandarin guts 79k original miles & being restored 1979 Chevy 2wd Short Wide aka "Emma-Jayne" Cordova brown with mandarin guts 2019 Chevy Tahoe LT Previous rides: -2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB. |
03-14-2013, 11:21 PM | #4 |
Yup. They're bastards. When I rebuilt my 87's suspension I just got them from Oreilly.
03-14-2013, 11:25 PM | #5 |
Take them to a spring shop or somewhere to have them taken out and pressed back in.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
03-15-2013, 02:02 AM | #6 | |
03-15-2013, 07:07 AM | #7 |
Watch out for your cornhole !
The factory control arms are better quality than aftermarket replacements. To me that makes it worth the effort.
03-15-2013, 07:22 AM | #8 |
buy new GM control arms with ball joints and everything pre installed from rock auto
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
03-15-2013, 08:27 AM | #9 |
How much are the new GM control arms with ball joints and everything pre installed from Rock Auto???
RIZ |
03-15-2013, 10:58 AM | #10 |
Four new AC Delco arms from Rocksuto are about 800 dollars plus shipping.
You can buy all new ball joints and bushings plus this bad boy and rebuild the original arms. When you're finished you'll still be in the job cheaper than buying new ones and you'll be left with a killer tool to use in the future. |
03-15-2013, 11:35 AM | #11 |
BAD BOW-Silverado XST
Ya doing it wrong!! First, using a hack saw, cut off the big round part of the rubber bushing. Once it's off, use a drill bit and drill through it. Drill enough out until you can pry it with pliers. I did this when I replaced my truck's bushings. Worked great. I took new polygraphite bushings, rods, and a-arms to a local alignment shop. The shop pressed new bushings in for $10 each.
03-15-2013, 12:52 PM | #12 | |
45D1134 45D1135 45D3315 45D3314
03-15-2013, 01:52 PM | #13 |
i agree with tex, plus i love new tools!
"DON'T TOUCH THE TRIM!!"-Early Kyler |
03-15-2013, 02:33 PM | #14 |
I've drilled them, ,sprayed it with lube so I've come to the conclusion that it is just not worth it
03-15-2013, 11:32 PM | #15 |
Don't know if you would be interested but you might look at this. http://www.rockauto.com/catalog/x,ca...parttype,10401
Sorry just seen it said 3/4 and 1 ton
03-19-2013, 07:52 PM | #16 | |
78K & 79C Jimmys
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
03-19-2013, 08:57 PM | #17 |
no man those are rebuildable....just put POR on them and your set LOL
03-20-2013, 12:16 AM | #18 | |
78K & 79C Jimmys
03-20-2013, 09:36 AM | #19 |
Go with OEM. I always try these:
oehq.com owarehouse.com autopartstomorrow.com gmpartsdirect.com Plus search Amazon and Ebay. Get the correct GM part numbers from Rock Auto first. |
03-20-2013, 01:02 PM | #20 |
Your truck is bagged, so why not just go with some porterbuilt forward arms or something similar?
Max Max's bagged 81 81 rcsb bagged, 22s, build in progress 09 ext cab, 24" U2's, DD sub/amp |
03-27-2013, 10:51 PM | #21 |
running of funds, lowers are a pain price wise
