Old 03-14-2013, 11:11 PM   #1
toddabrown
Clutch Fork Return Spring
Does anyone have some info on how this thing works? I just bought one from LMC. The spring end has a hook. I think it attaches inside the frame rail. The other end is straight! Do I have to bend that end? And where does it attach? Anybody got a picture of this thing in place? Thanks in advance for your help.
toddabrown is offline   Reply With Quote
Old 03-15-2013, 02:47 AM   #2
gmcdeadhead
gmcdeadhead's Avatar
Re: Clutch Fork Return Spring
i have to replace mine also , anybody with pics.
gmcdeadhead is offline   Reply With Quote
Old 03-16-2013, 05:41 PM   #3
gmcdeadhead
Anybody????
Old 03-16-2013, 06:13 PM   #4
northern 85
northern 85's Avatar
I will check with my friend he has the illusttrated book.
northern 85 is offline   Reply With Quote
Old 03-16-2013, 10:48 PM   #5
wrecked36
wrecked36's Avatar
You have to bend the straight end.
I hooked the spring into the fork, held it in position, then marked the straight end 2 inches rearward of a perfect hole in the frame. Took it off, bent it, then put the (formerly) straight end into the frame hole, secured it by bending in a way that it won't come out of the frame hole, then grabbed the spring end with pliers and hooked into the fork. Done deal, no problems
Big Jim
1966 C10 Short/Fleet canary yellow-I call her "Big Bird"
1979 K10 Short/Fleet blue-I call her "Cold Blue Steel"
2008 K2500 Duramax Crew Cab black paint I call him "Sir"
2006 H-D Street Glide black cherry paint I call her "Expensive"
wrecked36 is offline   Reply With Quote
