Old 03-14-2013, 11:47 PM   #1
cfurlan
cfurlan's Avatar
Dually Rear End Question
After working on my brakes today, I seen something for the first time. It's and 86 C30 Crew Cab. There is a bar that is mounted to the rear axle towards the passenger side that extends up to the frame. The mount on the frame swivels, I'm assuming when the axle goes up and down. I know it has the sway bar, but does anyone know what this other thing is?
cfurlan is offline   Reply With Quote
Old 03-15-2013, 01:33 AM   #2
wyattglock
wyattglock's Avatar
Re: Dually Rear End Question
Got any pictures? Does it have brake lines running in and out of it? If so, that is the rear proportioning valve. It gives you more rear brake bias as weight is put in the bed or on the bumper.
wyattglock is offline   Reply With Quote
Old 03-15-2013, 09:28 PM   #3
cfurlan
cfurlan's Avatar
Looks like at one time it had lines ran to it. Is it worth putting it back in working condition?
Old 03-15-2013, 09:32 PM   #4
wyattglock
wyattglock's Avatar
It might be. The biggest question there is, why was it unplumbed? Unfortunately, hooking it up is the only way to find out. I don't know of anyone that sells them, but maybe someone else will jump in and help me out with that. If you are going to haul or tow a lot, it would be worth giving it a shot. If you are just driving it with the occasional load, might not be worth it.
Old 03-16-2013, 03:31 PM   #5
Keith Seymore
Keith Seymore's Avatar
Other way around -
It sounds like the height sensing proportioning valve.
It was put there as "test beater" to pass the stopping distance portion of the federally mandated MVSS105 and MVSS208 brake tests. At curb, when there is less weight, the rear end sticks up and the brake line pressure is limited to the rear brakes, preventing lockup and skidding.
When weight is added, the rear end goes down, tripping the valve open and allowing full pressure to the rear brakes (and additional stopping power).
It's how we did it in the days before ABS braking.
You would probably be fine without it.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-16-2013, 04:51 PM   #6
meatwagon83
meatwagon83's Avatar
mine has one on it (not like im contributing, just sayin)
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 03-16-2013, 05:15 PM   #7
AntiGov
AntiGov's Avatar
I think im going to ditch mine when i swap the axle....
88 3+3 454 400 205 410 drw to srw still in pieces
90 3+3 350 400 205 410 srw
84 1/2 ton lb 6.2 4x4 parts truck
AntiGov is offline   Reply With Quote
Old 03-16-2013, 11:21 PM   #8
cfurlan
cfurlan's Avatar
Hey I appreciate all the comments and information from all of you. I ended up leaving it unhooked, a new one was around $400 and I don't think I'd benefit from it anyways.
Old 03-17-2013, 12:46 AM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
Did a 1/2 axle swap under a R3500 and bypassed the valve. Truck drives stops great.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 03-17-2013, 01:12 AM   #10
wiskers
wiskers's Avatar
I have a K30 CC, had a 14 bolt and swap a dana 70, took it off and threw it away. It works great without it.
wiskers is offline   Reply With Quote
