![]() Join Date: Nov 2007
Rocker Help before I place order.
I have some questions on parts before I place my order so I dont order parts I dont need.
On my drivers side, I am having to replace the floor, rocker, brace, pillar section. So my questions... Item 10 in LMC's pic. Is that a piece all on its own, or is that another "patch" that is included in items 3&4? I only found one piece of metal here. Item 12 that is for trucks. Does that go under the floor, or inside the rocker? I looking of ways to try and add extra bracing in this area. Also, if anyone knows of a thread that shows detailed pictures on repairing all this, please post a link. ![]()
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half ![]() 1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) |
Gone Fishing
Re: Rocker Help before I place order.
If its just the edge of the floor by the rocker go with #7. That is what im using on mine but just havent finished up my welding and grinding on it
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
Item 10 is a patch. It is part of 3, 4, or 7. I bought them by mistake and wound up using them as patch steel for other areas.
Item 12 is under the floor spot welded to the bottom of the floor pan. It runs front to rear. Mine was in good shape so I left it alone. You shouldn't need any reinforcement once all the steel is good. I have some pics in my build thread, but basically I just cut out all the rot and started piecing together what I needed from the patch panels. If you have any significant rust in the rockers, I would bet on needing #2, 8, and 9 as well. If the floor is bad you will likely need 13 and 16 as well. I also would recommend buying from somewhere other than LMC. The parts I got from them were so/so at best.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
your correct on item #10 thats a inner rocker panel parts of that are included in the other two items but you gotta be sure that you inners are good past the first set of cab support bolts theres 4 bolts on the cab supports front/rear and #10 only uses two of each
If you got item #7 it incorparates the peices together for less mess/fuss but its not needed if the front and rear of yor cab floor/inner rocker is good personally i think # 7 is the way too go that is if you need all that its allways a good idea to get a lil' more than what you think you need cause the evil rust is hideing there where you didnt think it is yep that # 8 & 9 is one of those peices that you dont see till its all off then you'll see "oh i need #8 & 9"
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
Thanks for the responses.
I already purchased 3,4,2 as I could visually see I needed them. I thought I got a pair of rockers from a local guy. They do not cover everything I need(the back area is not complete). So I need to get 13,8, and a rocker. What place sells better things? Ive heard many times lmc has crap sheetmetal but I thought it all came from the same place. I'm open for suggestions for better metal aslong as cost is not stupid more. |
search "mobile hotrod mechanic 67-72 chevy rocker" on youtube. he has a series of videos that show the whole thing front to back.
I think I have those parts from LMC at my office. or maybe i got them from brothers. i can check when i get to work. edit* nevermind i did get mine from brothers not lmc. and i just got the rocker and inner cowl replacements. |
:edit:
will search on videos later tonight. Thanks for that tip! Last edited by Dale99; 03-15-2013 at 10:08 AM. Reason: listed wrong vendor |
![]() Join Date: Jan 2013
Check GMC Paul he is a vendor on the site, everything I have read says his parts are awesome and shipping is reasonable. I am going to be ordering basically the same items for my 71, hope you post pics!
I bought my sheetmetal from Classic Parts. It might be the same stuff LMC sells, but IIRC they were a little cheaper and lower shipping.
http://www.classicparts.com/Patch-Panels/products/316/ I have become anti-LMC after several purchases. Unless they are the only place that has what I need, I look elsewhere.
#10 | |
I bought #7, but I did find I had to cut it in half to fit it in the truck. Wound up putting in the 2 pieces and welding them back together. For my rust I used 7, 3, 13, 16, 2, 8, and 9. I really should have bought 5 for the RH side, but I wound up making my own patch panel out of leftovers from the the floor pan patches. The LH side was fine in that area.
ok, correction. It was GMC pauls I had the problem with, not brothers. Dont want to slam the wrong vendor.
I will look at classics site. sloan, I have a build thread in my siggy. It will be slow going as I have never dug deeper then rockers before. Lattimer, I plan to use a 7 on the pass side. Thanks for tip on having to cut it in half. |
Check out my build thread I did a bunch of can work on mine it's in my signature
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
#13 | |
#14 |
the mobile hotrod videos on youtube are a must if you are planning on doing this yourself. ebfabman (a member here) has his own how to videos of the process, I've heard they are very nice. also, check out this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=271066 tons of great pics there, helped me out a lot. good luck! |
#15 |
![]() Join Date: Dec 2011
Good info here..subscribed
1972 Cheyenne Super 10 SWB,bucket seats,dealer cruise,tilt,tac,a/c,shoulder belts, 350/350 1971 K-10 Custom Deluxe 1971 K-10 Custom |
