![]() Join Date: Apr 2011
Adding Power Steering to 292
I picked these brackets and pump from an early 70's pickup it had an air pump on the driver side, one belt was driving the air pump and power steering.
Can I adapt them to install the p/s on my truck? Perhaps moving the alternator to the air pump location?
Make it a great day! Mike |
![]() Join Date: Jun 2011
Re: Adding Power Steering to 292
Man let me know i would love to have power steering on my 67 with a 292
I am a Referee of life.
Fickle Finn,,Did those come from a 292?They look a lo like my 250 brackets.I do know that 292 brackets are different from 250 ones.292 are also very hard to find.I'm not familiar with all of them but those have a larger hole in the center but look the same as mine otherwise.
You should be able to test fit by just fitting the bracket you have laid out (to the left in the pic).Try setting it in place by itself and you should be able to see if things are going to fit.It looks like the bracket will interfere with the bypass hose but will be hard to tell without putting it in place.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
They are from a 250 (4.1l). was just curious if I could move the alt to upper location which is where the air pump was located.
Guess I will just have to do the test fit to see what happens. thx
![]() Join Date: Dec 2012
post pics, this is exactly what I am trying to do on my 292. post your mock up. All of us with 292 would really appreciate it
Restoring America, one Chevy at a Time ![]() |
Tried to see if the brackets would work on my 292 today - bah no they won't. Would take a ton of work so not worth the time.
Went back to look at the truck, it is a 1976 Chevy, 250 with integrated head. I will put the brackets up for sale after I figure a fair price.
Is the pump pulley stamped with the part number 354539AA?
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
Don't know BMERDOC the pump and pulley are gone. Why?
No big deal. I have a '78 250 integral headed boat anchor in my 67. I'm installing P/S on it and my early pump had the wrong pulley on it. I found another one that was "good enough" but it should have a flat pulley on it. That pulley is impossible to find. All I could find was the part number and some pictures.
I have some old pulley's, I will look at them for you.
Don't worry about that part number. I just looked at the picture and saw that it was a non-keyed pulley. My pump is keyed. I'll live with what I have for now. As long as this motor is still chuging it has a home and I'll burn up a $8.00 belt every once in a while to get p/s. its just mis-aligned a tad. I don't drive it much anyway. Thanks though!
