Project underway - finally.
Leaf springs - what is stock?
My truck, 72 GMC long bed half ton, is undergoing restoration. As part of that, I have some plans for the rear suspension. I wanted to look at the original spring rates, but I am finding that none of the springs which are listed for this truck match what's under there. Currently it's 3 leaf plus an overload. Is this a stock pack? It looks it. Can anyone talk about what stock packs were available and what I have on here?
1972 GMC Pre-resto... awaiting allocated funding. |
Re: Leaf springs - what is stock?
What is listed on the SPID and what is the rear axle rating on the data plate?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
The original rear axle is gone. The tag says "G70 R suspension leaf spring".
Look my GMC references are limited on this. So I am trying to work it backward from the chevy side. They should be 1250-lb each, two-stage springs. BTW: If you need it, here are bruceman1968's decoders.
http://67-72chevytrucks.com/vboard/s...d.php?t=570059 So far it looks like a four leaf would be the stock C10/C1500 application. If you are wanting heavier springs the standard C20/C2500 five leaf would be the step up on a half ton truck.
Thanks Tim!
