Old 03-15-2013, 04:23 PM   #1
1967gm4x4
67 frame stands
Does any body have any pics of 4x4 small block frame stands and does anybody know where to get them.
1967 gmc 4x4 factory air factory buckets
1985 gmc high sierra 2500 4x4 400 1972 ford f250 4x4 390.Tomorrow is the most important thing in life. Comes into us very clean. It's perfect when it arrives and puts itself in our hands. It hopes we've learned something from yesterday. John Wayne
1967gm4x4 is offline   Reply With Quote
Old 03-15-2013, 06:49 PM   #2
Chance72
Chance72's Avatar
Re: 67 frame stands
Are you meaning like a rotisserie kind? Something like these?
Chance72 is offline   Reply With Quote
Old 03-15-2013, 07:02 PM   #3
Sammy
Re: 67 frame stands
Are you talking about engine mounts stands? Didn't think there was any difference just the position closest to the firewall to clear the engine cradle and transfer case.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 03-15-2013, 07:35 PM   #4
Chance72
Chance72's Avatar
Re: 67 frame stands
Oopps lol... Told my brother to put the frame stand pics on here while I go help my mom and he put the actual frame stand pics... Ok gotcha, This?
Old 03-15-2013, 08:48 PM   #5
SS Tim
SS Tim's Avatar
Re: 67 frame stands
This is a later Blazer setup, just can't remember if it is an I-6 or V-8. The assembly is often available used in the classified section. There are also aftermarket replacement mounts/crossmembers too. Generally those will also have a removable center section.
SS Tim is offline   Reply With Quote
Old 03-15-2013, 09:55 PM   #6
Chance72
Chance72's Avatar
Re: 67 frame stands
Got confused... Didn't read good enough. I'll stick to askin questions, Sorry guys.
Old 03-15-2013, 11:03 PM   #7
1967gm4x4
Re: 67 frame stands
My mounts and crossmember are identical to that but before the motor mounts sit flush the oil pan wants to hit the crossmember.
Old 03-15-2013, 11:32 PM   #8
SS Tim
SS Tim's Avatar
Re: 67 frame stands
Do you have the correct upper mounts and are they in good condition? If they sag the motor can touch, at least a 68 V6 K2500 GMC I knew did.
Do you have the correct oil pan?
Old 03-15-2013, 11:36 PM   #9
1967gm4x4
Re: 67 frame stands
I believe there correct the same ones off the big block that was in it, but i went and got brandnews from the auto parts store. It is a oil pan they would have ran throughout 73-87 I guess is the same?
Old 03-15-2013, 11:39 PM   #10
1967gm4x4
Re: 67 frame stands
Just like this one.
Old 03-15-2013, 11:42 PM   #11
1967gm4x4
Re: 67 frame stands
and upper mounts like this.
Old 03-15-2013, 11:58 PM   #12
SS Tim
SS Tim's Avatar
Re: 67 frame stands
Need to do some digging and get back to this. When it comes to square body crossover I'm lost.
Old 03-16-2013, 12:19 AM   #13
1967gm4x4
Re: 67 frame stands
I am lost right now to I have done plenty of square motor swaps but this is my first 67-72 swap do you know or have any pics of oil pans they ran with the 4x4 small blocks? Or if they even varied I have no clue.
