Old 03-15-2013, 05:24 PM   #1
afcamaro
afcamaro's Avatar
Door weatherstripping help
Having some isses with the inner window weatherstripping that goes from the top of the door, towards the back, and down the channel. They are both hanging up when rolling the window about halfway up. Is there some kind of trick to this, do I need to glue these in place to make sure the rubber isnt moving? thanks, Adam
afcamaro is offline   Reply With Quote
Old 03-15-2013, 06:47 PM   #2
truckster
truckster's Avatar
Re: Door weatherstripping help
I think you're talking about the window run. I've had the same problem. If they're worn, it can be especially bad.
The window felt isn't designed to be glued in; it's a press fit. I've found that if my regulator rollers and tracks are clean and lubricated, that I have far less problem with the windows hanging up on the felt. The regulator tends to push the glass toward the back of the opening when you're rolling it up, and having the tracks clean and lubricated helps the glass to be able to slide on the track.
truckster is offline   Reply With Quote
Old 03-15-2013, 07:53 PM   #3
Tinkermc
A good dose of wd-40 on the felts generally works very well
Tinkermc is offline   Reply With Quote
Old 03-15-2013, 09:59 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I use silicone spray on the window channel runs.Usually about every 6 mo.to a year and they're good to go.And you justt reminded me to do it.I thought about it today at the car wash(cars and coffeecruise in the am) and had forgotten until I saw this post.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-15-2013, 10:08 PM   #5
afcamaro
afcamaro's Avatar
Ok well the doors are brand new repros(from gmcpauls) which really arent that well fitting, and the felt is brand new as well. It does seem the window is getting pushed against the rear and pushing the rubber since the rubber doesnt stick in there really tight. I might tryin bending the track slighty to see if the rubber will press tighter.
Old 03-15-2013, 11:29 PM   #6
buckskins4ever
buckskins4ever's Avatar
I bought new from LMC. They fit great and are plenty long enough to cut off. They are a bit of a ***** to get out (your old ones) If they are just falling out when you roll your window down its def time to replace them.
buckskins4ever is offline   Reply With Quote
Old 03-16-2013, 11:09 AM   #7
afcamaro
afcamaro's Avatar
Sorry I didnt explain myself very well. The door and weatherstripping is all brand new. But I think I have a few ideas to try. Tried greasing everything, didnt help. Idk why these are being such a pain when everyone else says its easy. And ive put a few regulators in before.
Old 03-16-2013, 09:47 PM   #8
longbed67
longbed67's Avatar
I had the same problem with mine (also from gmc pauls) made by percision. I used a small dab of 3m weatherstrip adhesive up in the channel, and it took care of the problem. Yes it is like $15 per tube, but it is good stuff and I have found many uses for it!
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
