Old 03-15-2013, 06:43 PM   #1
1970 C10 MJW
1970 C10 MJW's Avatar
70 trailing arm question
i have a lot of rust inbetween the two portions of my trailing arms how can I remove that rust, because they are expanding can they be separated cleaned and then bolted together then welded? or do i need to replace?
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 03-15-2013, 06:50 PM   #2
Sammy
Re: 70 trailing arm question
Quickest is to just replace them. But if your up to it they can be split apart blasted n painted. Some even weld a plate on the top where they "T" together. But cleaning in between them is almost impossible without splitting them..
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 03-15-2013, 06:58 PM   #3
Sammy
I have seen them so badly rusted they had holes rusted through the sides the size of quarters. Forty plus years of salt n grime. Someone actually had a pic of a 67 or 68 truck where the arms give way after loading the truck full of wood.
Old 03-16-2013, 08:46 AM   #4
STPrider
STPrider's Avatar
Both of mine snapped right by the ubolts after getting some wheel hop. Its a big headache to fix them after they break, so I would recommend replacing them if you're worried about them at all! The porterbuilt arms are awesome!
'71 GMC pickup; "Ashley,"
STPrider is offline   Reply With Quote
Old 03-18-2013, 11:32 AM   #5
1970 C10 MJW
there is no way im spending that kind of money... so i spent several hours sat and sun... i have some pics of what i cut out and my repairs.. this is the worse side... the pass side arm isnt nearly as bad.. but as you can see they had huge holes...just took my time... and practiced my welding lol
Old 03-19-2013, 03:42 PM   #6
rocknss
rocknss's Avatar
If you do need to replace the trailing arms GMCPauls Truck Parts sells them individuality.
rocknss is offline   Reply With Quote
Old 03-20-2013, 10:07 AM   #7
1970 C10 MJW
well i think I have saved them... but I will not be buying replacements any time soon... they are way out of the budget..
