Old 03-15-2013, 07:04 PM   #1
primetime
primetime's Avatar
removing cab
i picked up a 68 shortbed for parts but having trouble with removing the cab. the driver front bolt isn't just rounded off, it has rust the parts of the head off. i can't get a socket, wrench, or vice grips on it. i don't want to potentially cause more damage to it (cause somebody might need it) but how do i get this thing off?
1968 Chevy C10 swb fleetside
2005 Chevy Silverado crew cab (SS)
1977 Goldwing cafe racer
1977 Chevy nova (first car/ first love)
primetime is offline   Reply With Quote
Old 03-15-2013, 07:25 PM   #2
Maladd
Re: removing cab
You are removing the nut from underneath correct? I just removed a cab and the bolt head inside the cab was broken and welded in place.
Maladd is offline   Reply With Quote
Old 03-15-2013, 07:40 PM   #3
primetime
primetime's Avatar
Re: removing cab
from underneath it just spins. so i was trying to hold it from top side but the head is disformed from years of rust. i'm just using the frame and maybe bedsides from this anyway. i just didnt want to cause more damage than necesary in case it was usable for someone else
Old 03-15-2013, 07:42 PM   #4
Lattimer
Lattimer's Avatar
Re: removing cab
Vise grips?
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 03-15-2013, 07:46 PM   #5
primetime
primetime's Avatar
Re: removing cab
parts rusty 68 stepper
Old 03-15-2013, 07:51 PM   #6
Tinkermc
Re: removing cab
I would suggest a cut off wheel or a recip saw.
Tinkermc is offline   Reply With Quote
Old 03-15-2013, 08:42 PM   #7
69SCSS
69SCSS's Avatar
Re: removing cab
I'm doing this exact thing tomorrow morning. Gonna just cut the bolt at the bottom, the nut is rusted to the bolt. I have a wrench on the top and a breaker on the bottom and no go!
Don't forget to remove the small ground straps! Know why I say that?
My 68 SWB
Al Silveira Music
<- My daughter loves this guy 8-)
69SCSS is offline   Reply With Quote
Old 03-15-2013, 09:00 PM   #8
Sklptrljay
Sklptrljay's Avatar
Re: removing cab
Grinder = no more bolt!
Sklptrljay is offline   Reply With Quote
Old 03-15-2013, 09:02 PM   #9
69SCSS
69SCSS's Avatar
Re: removing cab
My 68 SWB
Al Silveira Music
Old 03-16-2013, 08:02 AM   #10
oldno7
oldno7's Avatar
Re: removing cab
portabl sawsall if pos with long blade should be a quick fix
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am.
oldno7
oldno7 is offline   Reply With Quote
Old 03-21-2013, 05:16 PM   #11
primetime
primetime's Avatar
Re: removing cab
I used my angle grinder and dremel. Can't get the bolt off. so I cut a hole in the floor around it. There should be nothing holding this thing together to the rest of the cab!!!!! I don't understand why this point of the cab won't let go of the frame. The other 3 bolts were easy to come off. Just this freaking driver side front refuses to budge.
Old 03-21-2013, 06:02 PM   #12
69SCSS
69SCSS's Avatar
Re: removing cab
Put a cutoff wheel on the nut on the bottom and cut it off. I ground down probably 80% of the bolt, and I was just grinding the floor up. If you cut just the floorboard you still have a rail underneath the cab that is attached. You have to cut thru that too.
It took one cutting wheel to get the nut off the bolt and the whole thing snapped for me. Almost an hour total, over 30 minutes just grinding that head off the bolt. Wish I had just used the cutting wheel from the start!
My 68 SWB
Al Silveira Music
Old 03-21-2013, 06:07 PM   #13
Rich916
Rich916's Avatar
Re: removing cab
I had the same problem on my cab. Cutting wheel...Quick and easy!
71 Short Step Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=429946
Rich916 is offline   Reply With Quote
Old 03-21-2013, 06:27 PM   #14
57larry
Re: removing cab
use a hot wrench (torch)
57larry is offline   Reply With Quote
Old 03-21-2013, 08:17 PM   #15
schurg
Re: removing cab
put me in for one sawzall vote! right through the body bushing/bolt all at once. no damage to either body or frame...hopefully :P
schurg is offline   Reply With Quote
Old 03-21-2013, 08:18 PM   #16
69SCSS
69SCSS's Avatar
Re: removing cab
yea I tried the sawzall and had a hard time getting thru the nut, so just used the cutting wheel on the nut / bolt and BAM! all done.
My 68 SWB
Al Silveira Music
