Hey everyone i just finished rebuilding my front end on my truck as well as lowering it a couple more inches. After everything was installed i needed to get the front end realined. so on my way down to the shop i noticed my susoension making a loud noise every time i hit a pot hot. So my question is, is there a proper position for the front springs?
Re: Springs
i would think the loud noise is it bottoming out/// maybe even the crossmember hitting the pavement
Re: Springs
How much total drop does your truck have now? And yes, it is possible that the springs aren't seated correctly.
1970 SWB Build |
Re: Springs
I have a 4 inch drop in the front, I don't think ints bottoming out, it sounds more like the spring
Posted via Mobile Device |
Moderator
![]() Join Date: May 2007
Re: Springs
Probably hitting the bumpstops, or the crossmember on the pavement as cdowns said.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Re: Springs
If you didn't replace the shocks with shorter ones they are bottom out on travel. Likely that is the thump ur getting.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
