Old 03-16-2013, 06:13 PM   #1
slamed67
slamed67's Avatar
started 2001 5.3 vortec swap into 67 c10
slamed67 is offline   Reply With Quote
Old 03-16-2013, 06:15 PM   #2
slamed67
slamed67's Avatar
Re: started 2001 5.3 vortec swap into 67 c10
wheres a good place to send the harness and get a vats flash?
what all can be eliminated?
Old 03-16-2013, 08:25 PM   #3
kevmac
kevmac's Avatar
PSI, did a good job with my 67 Camaro, gonna use them again when I swap my 70 swb
kevmac is offline   Reply With Quote
Old 03-16-2013, 09:39 PM   #4
orngsikL
orngsikL's Avatar
lt1swap.com has all the info you need
build thread - 1972 C/10 "Ethyl"
1974 C/10 " Paw Paw"
C/10 Club Louisiana
instagram -
@esso_c10
@projectpawpaw
orngsikL is offline   Reply With Quote
Old 03-19-2013, 04:17 PM   #5
slamed67
slamed67's Avatar
Thumbs up Re: started 2001 5.3 vortec swap into 67 c10
ok kool gonna check both of those out right now. thanks for the info
Old 03-20-2013, 04:45 AM   #6
slamed67
slamed67's Avatar
ok so im using the pinout diagram from http://www.lt1swap.com/99-02_vortec_pcm.htm... and its for a "non emissions friendly stand alone harness.. my question is.. what about the upper, before cat, o2 sensors?? in this pinout all 4 are removed. on my headers there are bung holes for the sensors.. do i plug the holes and tune out all 4 sensors or keep the top 2? does the computer function better with or without? does it even matter?
Old 03-21-2013, 02:23 AM   #7
slamed67
slamed67's Avatar
[attach]Name:  733834_587454291264600_1976640326_n.jpg
Size:  36.5 KB[/attach]
Old 03-21-2013, 02:24 AM   #8
slamed67
slamed67's Avatar
i pulled the pins on the harness today and ill tape it up properly tomorrow
Old 03-21-2013, 03:44 AM   #9
SS Tim
SS Tim's Avatar
Have you been to the LSx swaps sub-forum of Engine and Drivetrain?
http://67-72chevytrucks.com/vboard/f...play.php?f=206
SS Tim is offline   Reply With Quote
Old 03-21-2013, 08:26 AM   #10
chev3600
chev3600's Avatar
Keep the before cat oxygen sensors. As long as you are fuel injected you need these. The ones after the cat can go away. They are only for monitoring the efficiency of the cats.
It's pretty satisfying when it starts up after you finish your own harness, but you really have to put some time in!
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 03-22-2013, 04:35 AM   #11
slamed67
slamed67's Avatar
thanks for the info on the o2 sensors. kept them in the harness along with maf.. yeah i was scared to death to start pulling pins until i pulled the first one and saw that all the wire colors were right where the numbers said they were.. it took me the better part of a day to weed the wires out.. when it came to the wires that led to the fuse box plug.. i wasnt sure.. but after digging deeper on http://www.lt1swap.com/99-02_vortec_pcm.htm it was all laid out right there
Old 03-23-2013, 09:42 PM   #12
slamed67
slamed67's Avatar
pulled this beat 350 out of the grease pit of an engine bay today!
Old 04-07-2013, 08:43 AM   #13
slamed67
slamed67's Avatar
