Old 03-16-2013, 11:28 PM   #1
msg
66 Driver window hard to roll up, how to adjust?
The driver window rolls down pretty easily, but as I roll it up it gets difficult to roll up right about mid way and 3/4 it jams up against the vent window frame. I have to grab the glass and roll up at the same time to get it to as far as it will go which leaves about 3/4 of an inch space.
Is there an adjustment that I can make to get it back on track?
msg is offline   Reply With Quote
Old 03-17-2013, 02:30 PM   #2
msg
Re: 66 Driver window hard to roll up, how to adjust?
Looks like the bar has lost the plastic wheel and has popped out and has been resting on the top of the track.
Is there a replacement plastic wheel to pop on, or does the regulator have to be removed and that stem be drilled out and a wheel added then welded back on?
And also I jave noticed that the vent window channel on both doors does not have a fuzzy looking channel groove the slide along, its just open. Should there be a channel to more tightly guide the glass up?
Here is a pic of the regulator bar that popped out of its track and is missing the roller.
Old 03-17-2013, 04:42 PM   #3
msg
noticed this as well
Shouldnt there be a coil for tension?
The passenger door has it but missing here.
Am I better off getting a new regulator? I imagine trying to mount one of those coils is a pain.
Old 03-17-2013, 05:51 PM   #4
msg
So with the coil missing, should I just buy a new regulator vs trying to replace all the rollers and coil? Ive been looking for just the coil and have not seen any yet, rollers I found here ..
http://www.classicparts.com/1964-72-.../#.UUY6vVvEoWM
Old 03-17-2013, 06:27 PM   #5
Hx16457
Hx16457's Avatar
Yep just replace the reg & be done with it!
You might like it so much that you jus get both sides!
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline   Reply With Quote
Old 03-17-2013, 09:13 PM   #6
rideblue00
rideblue00's Avatar
Get both new. They will work better.
rideblue00 is offline   Reply With Quote
Old 03-18-2013, 12:31 AM   #7
msg
Makes sense, I'll just order them both.
Question on the vent window bar that faces the edge of the roller window glass, shouldnt there be some channel slot to guide it? Mine is missing that fuzzy slider looking slot on both doors.
Old 03-18-2013, 09:51 AM   #8
msg
Originally Posted by Woogeroo View Post
yep, there is a channel felt, I think it is called that goes in there.
section 2 of the 60-66 faq index - under Glass, has a vent window rebuild article.
might show you what you need...
-W
Thanks Woogeroo, I had looked there prior to asking and didnt see any mention of the channel and was pretty sure it needs it. It just rattles around in there. It's strange cause mine has nothing at all in it on both sides. I would have expected some parts to have rotted away but its just 2 big ole empty slots.
Old 03-18-2013, 11:17 AM   #9
Wadewells
Easy to put in the channels and fuzzies, will make a world of difference. No adjustment though.
Pull the vent window and attached channel, two phillips head screws under the door panel then three along the edge of the door. Another removable channel behind the window held in with large phillips screws. Channel pops in easily, I used a little 3M Super Weatherstrip adhesive to keep everything in place.
Yes, don't futz around with that old regulator, get a new one or complete used one.
Lube the rollers and channels with a little white grease.
Wadewells is offline   Reply With Quote
Old 03-18-2013, 11:29 AM   #10
msg
Much appreciated guys! Might as well restore the vents while I'm at it.
Old 03-20-2013, 10:43 AM   #11
gabe2000
I window does not close completely because the metal bar that holds the glass stop with door window opening. i guess the OP leaned on thw door until it close it tighter. iam going use brake cliper tool to expanse the door window lip openning
gabe2000 is offline   Reply With Quote
