Any 6.0\TH350-400's out there
Got the truck running but I know nothing about the old school trannies (no not Rupal)...lol. Had my ecm programmed for it, in conjunction with a dakota digital sender for the vss signal to the ecm.
A buddy had to remind me to hook up the modulator. What is the ideal setup for this trans? How are people hooking up the kickdown cable and are they using the stock throttle body? I simply modified the original '84 C10 cable and attached it to the throttle body...but I now need to hook up the kick down. |
Re: Any 6.0\TH350-400's out there
Are you running a TH350 or TH400, TH350 uses a cable. TH400 is electrical.
Truck and auto performance nut
I ran a 200-4r. You need to make sure you have the TV cable mounting right brackets and pulling the TV cable at the right ratio to the throttle body movement.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
