Old 03-17-2013, 12:02 PM   #1
shadow1967
shadow1967's Avatar
For thous interested in a LS or Coyote preoiler
Here is my preluber to help thous who's projects got delay doto life getting in the way. You could get fancy an use AN style fittings but why spend money needlessly, unless you are a engine builder. I went though the trouble of welding a AN fitting to a 12mm x1.5 thread to attach a hose to drain back to the bucket. A waste of time, the hole was to small, so slow return. Cut hole in lid bigger and just pull the drain plug. I searched high and low for a oil pump from my friends. To my behold 2 days later there was a pump in a baggy at my door(free). Now tap the top for a 1/4 npt. A bucket and lid About 6 bucks, 1/4 x 4" tube @1.50, 3/4od x 1/2id x 10ft @4.17 and 4 hose clamps. Oh and 2 pieces of scrape to reinforce the lid. I use sheet metal that was the body corners. When you put the tubing on use a heat gun the warm(not melt) so as to ease with sliding on of the tubing over the threads or cut the threads off. As you can see I have low cost and not much effort, you to can have a preluber.
Build for my 1959 Fleetside...
http://67-72chevytrucks.com/vboard/s...d.php?t=518308
shadow1967 is offline   Reply With Quote
Old 03-17-2013, 12:03 PM   #2
shadow1967
shadow1967's Avatar
Re: For thous interested in a LS or Coyote preoiler
The rest......
Old 03-17-2013, 02:07 PM   #3
solidaxel
solidaxel's Avatar
Thanks even I can follow those instructions, and I have a not so new pump to make this work
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-17-2013, 08:11 PM   #4
Kim57
Kim57's Avatar
Very cool. thanks.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
