Old 03-17-2013, 12:31 PM   #1
70chevytruck
why does the fuse blow to taillights
Only when the headlights are on and driving. Replaced the headlight switch and this truck came from Arizona.....sockets look good. All lights work and the wiring harness to taillights look real good.
Does not blow fuse when I disconnect wiring harness at back of truck so its not the dome light or door switches I would guess.
How do I track this down?
70chevytruck
70chevytruck is offline   Reply With Quote
Old 03-17-2013, 12:44 PM   #2
Lee H
Lee H's Avatar
Re: why does the fuse blow to taillights
Pull the bulbs and try again. Add one buld and try, then swap. I'd bet one of the tail light housings are shorted out.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 03-17-2013, 12:57 PM   #3
jhwkns
Registered Cruiser
jhwkns's Avatar
It seems like you already did.
Give everything a close visual inspection for cracked wires, and bad grounds. Be suspicious of anywhere someone's tride to hook up trailer lights. Check, and clean all grounds.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 03-17-2013, 01:52 PM   #4
biggestjohn
Fuses blow because excess current is flowing thru them.( turn on headlights increases current flow) Disconnecting wiring isn't necessarily going to help you track this down. Check to make certain that you have correct size fuse 2. Connect a volt meter in line to check amp flow looking for excess flow. The meter should be placed in an open in the circuit, thus completing the circuit.(ie: unplug connector,connect meter probes in voltage feed line, jumper the other connections) Electrical problems can be a pita to solve.
Your light bulbs act as the resistors in your circuits, regulating the flow of current. Somewhere in the circuit current is bypassing the bulbs creating what is known as a short, a "short cut to ground"
You can check your plugs and sockets for shorts by unplugging them and checking them for continuity,(lights turned off) there should be no flow thru the plug/socket.
......its not what your askin', its what your gettin'....
.......every time I screw up, I learn something. Needless to say, I'm learning all the time............
biggestjohn is offline   Reply With Quote
Old 03-17-2013, 04:38 PM   #5
cdowns
cdowns's Avatar
use good tools and check inch by inch of the wiring// especially the few places where the metal clips hold it in place in the frame rail
also look for bubba splices where they hooked up traila lights
Old 03-17-2013, 07:47 PM   #6
buckskins4ever
buckskins4ever's Avatar
you def got a short somewhere in the rear.
buckskins4ever is offline   Reply With Quote
