Old 03-17-2013, 03:13 PM   #1
JCampbell
EGR Fun (Code 32)
Trying to diagnose an EGR issue. Typical code 32: SES light @ constant throttle on hwy, pinging @ light throttle, etc.
Ran the standard EGR valve tests: EGR valve takes and holds 15" of vacuum with no appreciable signs of loss. Engine stumbles when EGR is manually engaged at idle. Vacuum source @ TB shows 20" of vacuum @ 2500-3000 RPM. Vacuum lines are all intact and connected correctly.
Could the issue be at the EGR solenoid? Any way to test this? Am I missing something?
JCampbell is offline   Reply With Quote
Old 03-17-2013, 03:26 PM   #2
AntiGov
AntiGov's Avatar
Re: EGR Fun (Code 32)
got no flippin answer for you..................just hope you figure it out bro..
88 3+3 454 400 205 410 drw to srw still in pieces
90 3+3 350 400 205 410 srw
84 1/2 ton lb 6.2 4x4 parts truck
AntiGov is offline   Reply With Quote
Old 03-17-2013, 04:58 PM   #3
manimal
manimal's Avatar
I am going through the same issues with my 'Burb. I am going to pull the intake and clean all the passages and also replace my solenoid. I have very little stumble,but does not register vac on the EGR side of the solenoid.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 03-17-2013, 04:59 PM   #4
manimal
manimal's Avatar
Did you check the vacuum at the EGR side of the solenoid?
-Lance
Old 03-17-2013, 05:04 PM   #5
Sabaka454
Sabaka454's Avatar
check the EGR solenoid.
Sabaka454 is offline   Reply With Quote
Old 03-17-2013, 05:56 PM   #6
JCampbell
Epic chart, Sabaka. Thanks!
Old 03-19-2013, 07:44 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
knock sensor
mine was broke off the block (88 350 block)
I didn't have a code,just those issues
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 05-04-2013, 10:15 PM   #8
chris989
Did you find your problem? I am having issues and i just checked the vacuum on the solenoid valve. It will not hold vacuum and it sounds like a small whoopi cushion. If I understand the chart, this part is bad.
I hate to spend another 50$ for the solenoid if I am misunderstanding the chart.
Chris
chris989 is offline   Reply With Quote
