Top Repair
My top is in need of some desperate repair. The edges have multiple chips.
![]() The top looks like the PO ran the edge of a DA and took some chunks out. ![]() It also looks like the fibers are showing on top. ![]() What should I do about the top of the top where the fibers are showing? Do I need a skim layer of fiberglass or can I prime over it? Or thin coat of bondo? Any suggestions are appreciated.
1951 Chevy 3100/S-10: http://67-72chevytrucks.com/vboard/s...d.php?t=406072 1957 Chevy 3200 1971 2WD Blazer - Sold |
Re: Top Repair
Evercoat Fiber Tech works realy well, and is made for SMC. Theses tops are not fiberglass they are sheet molded composite (SMC). It worked real well on my top for all the chips and pot holes.
Posted via Mobile Device |
#3 | |
Re: Top Repair
I'm still not sure what to do about the areas on the very top where you can see the fibers. Is that what you're calling "pot holes"? If so, would the Evercoat Fiber Tech be thin enough to spread over that large of an area? Thanks, Matt
Re: Top Repair
I filled the cracks and holes with the Evercoat product then shot it with u-pol raptor liner.
J. Milligan 1972 GMC Jimmy 1955 Willys PU 1959 Willys PU |
Re: Top Repair
I have a small missing piece in the top gutter above the drivers window. Do you think either of these products would work to repair this?
Re: Top Repair
I would think so. I put it on a little to thick to accommodate for my lack of confidence in smc repair, which results in a ton of extra sanding. Good luck.
Re: Top Repair
![]() ![]() I ended up putting a light coat (what I would call "skim coat") on the entire top to fill all the small holes where the fibers were showing. LOTS of sanding ahead. I'll try to update as I go. Posted via Mobile Device
Boosted Member
Re: Top Repair
Subscribed.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
![]() Join Date: Nov 2007
Re: Top Repair
Me too
Re: Top Repair
Have you sanded it yet?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Re: Top Repair
I'm pretty poor at bodywork, but I did get done sanding. The edges where i had to use mat actually turned out really well. It was surprisingly easy to work with the epoxy. I dropped it off to get painted today. I'll post some pics when I get it back.
Posted via Mobile Device Posted via Mobile Device
![]() Join Date: Apr 2006
Re: Top Repair
Did you take some pics of the repair for the chip that's missing? I have a single wall with a pretty good size chunk missing where it bolts to the bed. I'm wondering how I might fix it.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
#13 |
Re: Top Repair
I had the same problem, I used a short section of angle iron clamped to the missing area and laid sections of fiberglass mat with mixed resin to match up with existing rail, two to three layers. When dry I removed the angle iron and started sanding, not noticable at all after painting. I'll post pics if I can find them.
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
#14 | |
Re: Top Repair
It's getting painted hopefully this week. I'll try to remember to post pics when it's done. Posted via Mobile Device
#15 |
Re: Top Repair
Picking up the top tomorrow. I'm assuming all the rubber will need to be replaced around the edges. Is there rubber across the front? Mine doesn't have any, but I'm sure there was supposed to be some there.
I'll post some pics tomorrow. Posted via Mobile Device
#16 |
Re: Top Repair
Yes, most of the vendors here sell all of the seals, LMC catalog has some good pics of the breakdown of the placement.
#17 |
Re: Top Repair
#18 |
Re: Top Repair
Looks real nice! Jealous
#19 |
Boosted Member
Re: Top Repair
That is beautiful!
#20 |
Re: Top Repair
Do you have any pics of how the Raptor liner turned out
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
#21 | |
Re: Top Repair
Nice, what did you use to get the texture
#22 |
Re: Top Repair
great thread - also have the same issues...
in addition; The top bar of my rear hatch split and broke apart...so you guys are saying that fiberglass repair wont do it huh? what can i use to patch that baby back together? |
#23 |
Re: Top Repair
Zolatone was the name of the textured paint. My uncles shop sprayed it on. It covered up a ton of imperfections. Then sprayed a semigloss white on top of it.
#24 |
Re: Top Repair
Zolatone is nice stuff. Oil base - water base and ink if I remember right. Do not stir!
#25 | |
Re: Top Repair
