03-17-2013, 06:27 PM | #1 |
Patch panels for cab corners
Here is my truck...http://67-72chevytrucks.com/vboard/s...d.php?t=403630
Now, do I need to do the patch panels, if so, best place to get them? Is there a better easier fix for the rust? |
03-18-2013, 07:12 AM | #2 |
Re: Patch panels for cab corners
Looks like it rusted from the inside i would cut it open see how bad it is first then order what you need to fix it.As far as sheet metal a vendor on here http://store.73-87chevytrucks.com/me...tegory_Code=C1
03-18-2013, 07:12 AM | #3 |
I got mine from LMC.
If you check my build/intro thread linked below you can see the repair. Rather than welding I used the panel adhesive. Seems to be holdling up well. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-18-2013, 09:06 AM | #4 |
My body man says that he glues alot of panels. He is getting ready to glue a few pieces on my bed. That is what they do on the newer vehicles from factory. As long as they are not a structural panel.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
