Old 03-17-2013, 09:12 PM   #1
mikes61
Need Help slammin a 61 Apache!!
Hey guys im a newb on this site just looking for suggestions
on slammin my 61. Here's what i had in mind.
urning torsion bars all the way down
2.5 drop spindles
Disc brake conversion
5 lug conversion
4" drop spring in back
20x10 in back with 295 tires
20x8.5 in front with 255 tires.
What are your thoughts? Thanks in advance!!
mikes61 is offline   Reply With Quote
Old 03-18-2013, 11:47 AM   #2
mikes61
Re: Need Help slammin a 61 Apache!!
Any help would be appreciated.
Old 03-18-2013, 01:34 PM   #3
doobiebro
doobiebro's Avatar
Not a great pic but heres my 60 2 1/2 dropped spindles disc brake convertion with 4" drop coils in the rear. I also turned the torsion bars and lowered it maybe 3" more. Bottom of the bolts on the torsion bar is about 4" from the ground... running 7" smoothies 6 lug. you might have a rubbing problem with the 10" need to check..
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 03-18-2013, 01:56 PM   #4
hop sing
hop sing's Avatar
nice stance !if u dont mind me asking what company did u get ur spindles from thx hop
hop sing is offline   Reply With Quote
Old 03-18-2013, 02:28 PM   #5
mikes61
Thanks for the imput! Do you have any issues with the 4" drop coils in the rear. I dont really want to c notch.
Old 03-18-2013, 02:45 PM   #6
doobiebro
doobiebro's Avatar
Got all my stuff from CPP 5 years ago and very happy with thier products... I also installed a dual master cylinder and brake booster..heres another pic..
Old 03-18-2013, 02:52 PM   #7
doobiebro
doobiebro's Avatar
Nope not at all... I can probably still install 2" blocks at the rear but not gonna do it.. heres a rear view pic..
Old 03-18-2013, 04:43 PM   #8
forestb
forestb's Avatar
I had 2.5 inch drop spindles and the torsion bars lowered 2 inches and that worked fine. the nice thing about torsion bars is you can always go back up. make sure you count how many times you turn the bolts and remember it takes a little driving to get them to settle. A 5.5 inch drop in the front and 4 in the back will give you one heck of a rake. I think you can go as low a 5.5 in the back without notching the frame but you will need to get rid of the bump stops.
forestb is offline   Reply With Quote
Old 03-18-2013, 04:50 PM   #9
LVPhotos
LVPhotos's Avatar
Going with Porterbuilt front, but took the bump stops out up front. The rear has bags and won't go lower with out two piece driveshaft, bumpstops keep the shaft from hitting. No spindles yet but when time comes it will. Look at projects and builds for pictures and my cardomain page as well.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 03-18-2013, 04:52 PM   #10
LVPhotos
LVPhotos's Avatar
One with out hood.
Old 03-19-2013, 03:44 PM   #11
verdell
verdell's Avatar
I too bought the 2.5 inch dropped spindles and 6 lug disc brake from CPP and kept my torsion bars. Rode it for a while with rear coils that I lowered with torch but later sprung for the 4 in drops and improved the ride. Threw on a dual diaphram master/booster also and sway bar. Good thing about the torsion bars is you can lower or raise the front with ease for a wicked rake. Been running this set up since '01. I started to swap the front suspension for coil springs but I think im gonna hold on to what I have. I plan on bags as well but don't intend to slam it to the pavement. Been pleased so far but want a more of a 'cadillac' comfort ride in the near future..
verdell is offline   Reply With Quote
Old 03-21-2013, 09:24 AM   #12
mikes61
Where did you get the dual diaphram master?
Old 03-21-2013, 03:52 PM   #13
verdell
verdell's Avatar
..I meant dual master cylinder and a dual diaphragm booster.
Sorry, thought it was implied.
Old 03-22-2013, 09:27 AM   #14
mikes61
Verdell is your truck a auto or manual ?
Old 03-22-2013, 11:45 AM   #15
cori 64
cori 64's Avatar
Are those the stock wheels?I've read that the stock ones will not clear the cailpers.
cori 64 is offline   Reply With Quote
Old 03-22-2013, 03:00 PM   #16
doobiebro
doobiebro's Avatar
No they are 7" smoothies from (Wheel Vintiques)... and you are correct - stock wheels will not clear the calipers...
Old 03-22-2013, 04:45 PM   #17
verdell
verdell's Avatar
My '60 has an automatic..700r4..
Old 03-22-2013, 05:37 PM   #18
mikes61
Thanks !
