Old 03-18-2013, 12:15 AM   #1
naisugai
86 c10 battery terminal wiring
I recently bought a used 86 C10 and noticed that some of the accessory wiring is running to some type of resistor on the front radiator support, instead of running directly to the battery.
Could someone explain why this is needed?
Thanks!
Also,
I am wanting to upgrade my battery terminal wiring (to the starter and alternator) any suggestions there?
naisugai is offline   Reply With Quote
Old 03-18-2013, 02:44 AM   #2
Psycho_SWB
Re: 86 c10 battery terminal wiring
Do you have a photo of what's on the front radiator support?
Psycho_SWB is offline   Reply With Quote
Old 03-18-2013, 09:10 AM   #3
bilfman
bilfman's Avatar
Does it have 3 wires running to it 2 large and a small? If so it could be a factory relay. Basically a switch used for running something with a larger amp draw, possibly a camper.
Or it could be a battery isolator, if it has cooling fins/ribs on it it is probably an isolator.
But the best thing you can ever do when asking a "What is this" post, is put up a picture, saves us from using our imagination and guessing.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 03-19-2013, 01:10 AM   #4
naisugai
Sorry,
Link to picture:
Old 03-19-2013, 01:16 AM   #5
king-918
king-918's Avatar
Originally Posted by naisugai View Post
<object name="Slideshow" id="Slideshow" width="425" height="425" align="middle" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab" classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000"><param name="movie" value="http://www.shutterfly.com/flashapps/flashslideshow/Slideshow.swf" /><param name="flashvars" value="configurl=http%3A%2F%2Fws.shutterfly.com%2Fshare%2Fexternal_slideshow_config%3Fsid%3D1AZMnDJu 3bNnJQ" /><param name="allowscriptaccess" value="always" /><embed id="Slideshow" width="425" height="425" name="Slideshow" align="middle" quality="high" type="application/x-shockwave-flash" flashvars="configurl=http%3A%2F%2Fws.shutterfly.com%2Fshare%2Fexternal_slideshow_config%3Fsid%3D1AZM nDJu3bNnJQ" pluginspage="http://www.adobe.com/go/getflashplayer" allowscriptaccess="always" allowfullscreen="true" bgcolor="#869ca7" src="http://www.shutterfly.com/flashapps/flashslideshow/Slideshow.swf"></embed></object><p style="width:425px;margin-top:0;text-align:center;"><a href="http://share.shutterfly.com/action/welcome?sid=1AZMnDJu3bNnJQ&eid=118">Click here to view these pictures larger</a></p>
Sorry,
Here is a picture:
I love the matrix but I'm not to this point yet.
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 03-19-2013, 01:19 AM   #6
naisugai
Good one...
Old 03-19-2013, 11:36 PM   #7
naisugai
Anyone able to help shed some light on what these are for and do I really need them?
Old 03-19-2013, 11:48 PM   #8
JellyBeanDriver
That is a circuit breaker, not a resistor.
Don't know what they were powering, but some things may have been:
- headlight relay mod
- trailer wiring
JellyBeanDriver is offline   Reply With Quote
Old 03-20-2013, 02:00 AM   #9
naisugai
Thanks! I appreciate the response!
Old 03-20-2013, 11:42 AM   #10
Psycho_SWB
It looks like somebody had a lot of aftermarket accessories wired through the breaker. Nothing is connected to it now, but the main wire, which I'm assuming is going to the battery. Not sure if it's a positive connection or a ground since they used black wire. You can disconnect that wire going to it and remove the breaker.
Old 03-20-2013, 12:56 PM   #11
silvereagle07
silvereagle07's Avatar
If your not going to need it take it off and terminate it at the battery.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 03-20-2013, 02:39 PM   #12
naisugai
Thats what I was thinking. Just trying to clean up the engine bay.
Thanks!
