Old 03-18-2013, 10:10 AM   #1
biohazardbill
Air suspension push in fittings issues
So doing an air test on my truck i set all 4 airbags to max height and let it sit over night.
Rear bags both dropped about 3 lbs, front left dropped 5 lbs and right front dropped 30.
I figured the the that had small drops in pressure was possibly due to temp change during the night.
So I disassembled the pass side and re sealed the fittings, reassembled, retested all was well.
So I had to reroute my lines for other reasons.
Rerouted pass side and drivers side front. Tested. drivers side now drops in pressure over night. Took apart resealed, retested, pass side now dropping over night and I didnt even touch that side since the previous test.
Rear has had no issues however really dont have any weight on it either.
Ideas?
Swap out fittings for compression fittings?
biohazardbill is offline   Reply With Quote
Old 03-18-2013, 10:20 AM   #2
Pro Performance
Pro Performance's Avatar
Re: Air suspension push in fittings issues
A good way to track down leaks is with soapy water. What are you using for thread sealant? A good one to use is Loctite 545. It might be leaking through your threads and not the PTC itself.
When using PTC fittings, just make sure to cut the line very square at the end, and fully insert until it bottoms out. Then give it a light tug to ensure it is seated and the PTC fittings it grabbing it.
The soapy water will help track down that leak though.
- Travis
Pro Performance is offline   Reply With Quote
Old 03-18-2013, 10:44 AM   #3
biohazardbill
Problem is I cannot actually visually see those fittings in the crossmember and it is such a slow leak i dont forsee it making bubbles right away.
The sealant I use is
ARP Thread Sealant
All cuts are made with the air line cutter I got from Ride Tech.
I have pushed the line in several times to make sure that it has been fully inserted.
Driving me nuts lol
Old 03-18-2013, 11:02 AM   #4
Pro Performance
Sometimes tracing down these leaks can be frustrating. Best thing to do is pull the brackets so you can spray them down with soapy water. If it isn't the threads of the PTC fittings, then check the bag itself by spraying it down. Bags don't leak that often, but it is possible.
What valves are you using? Some require some sort of tank pressure to completely close off. Is it leaking at the valve end?
Old 03-18-2013, 12:59 PM   #5
jimmydean
jimmydean's Avatar
I used soapy water last time with great results. My issue was the opposite, mine would inflate one rear bag while sitting. It took a while to track it all down, but I did. Best of luck, I know how frustrating it can be.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 03-18-2013, 01:16 PM   #6
PBFAB.COM
PBFAB.COM's Avatar
One thing that we have found, is that once you put a virgin line into a PTC fitting it will put a little barb/scratch on the line. If you remove the line and reinsert it into the PTC without trimming off the end section of the line so it is fresh and smooth, it will usually cause a small leak.
Make sure if you remove the line, you trim off about 1/4" of the line before you reinsert it.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 03-18-2013, 01:26 PM   #7
biohazardbill
Nate
This makes sense and why one side started leaking after rerouting the line.
I will try this on the front once I get the rear end back together... (doing an axle shaft swap at the moment to get the 5 lug pattern)
Will let you guys know what happens
Old 04-09-2013, 08:56 AM   #8
biohazardbill
Ok
So I was waiting til I installed the levelling sensors before tackling this issue.
Line completely disconnected, trimmed about a half inch off both ends. Passenger side still has a slow leak. Lost 10-12 lbs overnight.
Would it hurt the bag if I removed it completely and put 100lbs of pressure or so in it with no resistance so I can check the fitting?
Old 04-09-2013, 02:36 PM   #9
northeimcustom
northeimcustom's Avatar
Originally Posted by biohazardbill View Post
Ok
i wouldnt think so, as long as the bag doesnt go past its height limit.
*^MY BUILD STORY^*
northeimcustom is offline   Reply With Quote
Old 04-09-2013, 03:36 PM   #10
smoknbarrels
Registered Mail
smoknbarrels's Avatar
not sure what brand bags they use? but I inflate my slams with no load to 150psi all the time. doesn't hurt them. as long as you dont go over the rated pressure (200psi in my case), height limit means nothing.
smoknbarrels is offline   Reply With Quote
Old 04-09-2013, 03:42 PM   #11
biohazardbill
I have the SS 8 bags.
Another question while we are on the subject. Since I lost about 12 lbs of pressure last night, that is about 1 lb per hour... super slow leak. Any ideas on how to check where the leak is other than the obvious soapy water and watch it?
Old 04-09-2013, 03:57 PM   #12
jimmydean
jimmydean's Avatar
Soapy water is about all you can do unless you can submerge the whole system in water and look for bubbles like you do when patching a tire.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 04-09-2013, 03:58 PM   #13
biohazardbill
I do have a lake out back, might just drive the whole truck into it lol
Old 04-12-2013, 07:31 AM   #14
Square_78
Square_78's Avatar
Hahahahaha!
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
