Spark plug wire retainers
Is this the factory spark plug retainer? If so can I buy this one from any vendors or is it only a part i have to find used?I have seen the other styles for sale which are the one that holds the 2 wires under that heat shields and the ones that bolt to back of block that holds the 4 wires for each side. Any info would be appreciated. Pics would help a lot of exactly where this retainer attaches on the engine. Thanks
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
Re: Spark plug wire retainers
Ttt
![]() Join Date: Dec 2011
Here's the one on my '72 with automatic. The one on my '71 k10 with 4 speed is like the one in your pic only it points forward rather then back to the firewall like yours. Camaro vendors sell both styles.
Posted via Mobile Device Posted via Mobile Device
1972 Cheyenne Super 10 SWB,bucket seats,dealer cruise,tilt,tac,a/c,shoulder belts, 350/350 1971 K-10 Custom Deluxe 1971 K-10 Custom |
Thanks I have that same bracket. I just took that pic off from the forum not my bracket. Just missing the black wire clip on top. What does the one on the other side of the engine look like. Do you have any other pics. I am working on my truck now and trying to figure the correct routing. Thanks
Here are two more let me know if you need a certain angle
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
I just now realized we basically have the same 72 according to our sigs
#8 | |
Do you have a pic of the retainer that bolts on oil pan and heat shields? Do the wires go behind motor mount or in front? Thanks again
I didn't see any on the oil pan, maybe I'm missing that one. First pic is drivers side, second is pass.
Both are above motor mounts
Great thanks again!
#13 |
What?
I really like the OE wire retainers, though they only work well with 7mm wires.
8mm wires are too fat for them, unless there is someone that makes them specifically for 8mm.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
#14 | |
#15 | |
#16 |
![]() Join Date: May 2010
Here's a picture that shows the clip on the oil pan (one on each side). I don't have the heat shields mounted since this is a GMPP crate engine and does not have tapped holes for the shield bolts.
#17 | |
![]() Posted via Mobile Device
1972 Cheyenne Super 10 SWB,bucket seats,dealer cruise,tilt,tac,a/c,shoulder belts, 350/350 1971 K-10 Custom Deluxe 1971 K-10 Custom Last edited by med.bronze; 03-19-2013 at 09:18 AM. Reason: Spelling |
#18 | |
