Old 03-18-2013, 01:20 PM   #1
65Gregg
65Gregg's Avatar
U bolts are whipping me
I'm in the process of bolting up my fresh rear end and have gotten into a fight with the U bolts. They barely fit through the axle perches, not a diameter issue but the distance they are spread. When I try to put my lowering blocks on, well it ain't gonna happen. The holes in the blocks are about 1/2 inch wider than the u bolts. I haven't tried to see how they fit in the trailing arms yet but my old and tired butt can't spread them apart enough to fit the blocks. Any ideas or suggestions. If they fit the trailing arms ok at the current width I'll probably have the blocks machined to fit.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 03-18-2013, 03:30 PM   #2
Custom 68
Custom 68's Avatar
Re: U bolts are whipping me
clamp them up in a vise (away from the threads) and grab a big long pipe and slip it over one leg and give them a little adjustment. You should be able to spread them that way.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 03-18-2013, 04:14 PM   #3
cdowns
cdowns's Avatar
i would first check that the holes in the drop blocks align with the holes in the trailing arms// if they r not a match i'd b lookin at gettin blocks that are drilled right
Old 03-18-2013, 11:04 PM   #4
65Gregg
65Gregg's Avatar
The u bolts fit the trailing arm just fine, they fit in the blocks just fine but when the bolts went into the holes on the housing everything changed. As long as the u bolts were only part of the way in everything still fit, as soon as they were seated against the axle they got squeezed to the point nothing fit. The solution was to only push the u bolt on part of the way, put the blocks on with enough of the bolt exposed to start in the trailing arm. Then I used a floor jack to push everything together. I used a 4x4 between the frame and the u bolt then jacked up the trailing arm-done!
65Gregg
Blue long bed
White TBSS
61 Impala
Old 03-18-2013, 11:08 PM   #5
mud.man.rj
mud.man.rj's Avatar
The old try and try again trick, you got it though, good job, bet your glad it's over.
mud.man.rj is offline   Reply With Quote
