Old 03-18-2013, 01:31 PM   #1
David623
Transfer case rubber mounts
I need help finding the right rubber bushings, I have a 1999 5.3 vortex motor with the 4L60E hooked up to the NP 205 transfer case, it looks like I will be able to use the original cross member, but I do not have rubber bushing for the bottom cross member and the ones for the side of the Transfer case that bolts to the frame. I think I have located the bottom bushings, but I have not found anything listing for the side of the transfer case? The transfer case is the original one in my 72 Jimmie.
David623 is offline   Reply With Quote
Old 03-18-2013, 10:19 PM   #2
Jdubs71
Jdubs71's Avatar
Re: Transfer case rubber mounts
Energy suspension p/n 31106 Transfer Case Mount
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
Old 03-18-2013, 10:20 PM   #3
Jdubs71
Jdubs71's Avatar
A picture of it
My build thread
