Old 03-18-2013, 03:51 PM   #1
jobee1967
67 C-10 5.3 swap questions
This is my first post, so go easy on me. I'm in the process of restoring the 67 c-10 longbed stepside my late grandpa bought new. Decided to do a 5.3 LS/ TH400 swap to make it a little more fun to drive than the original 250 / 3 speed. Here is the question....is there a set of mounts available to bolt the 5.3 up to my 6 cylinder frame towers? Thanks in advance.
Jason
jobee1967 is offline   Reply With Quote
Old 03-18-2013, 04:05 PM   #2
Sbehie
Re: 67 C-10 5.3 swap questions
Not a 100% but I think if you search "Dirty Dingo" is a company out of AZ that makes those.
Sbehie is offline   Reply With Quote
Old 03-18-2013, 04:15 PM   #3
Mint68
Mint68's Avatar
Check this section out, there is a FAQ section that may have your answer. I think being a 2wheel drive makes it easier. Maybe ask a moderator to move your post there and it might get more traffic.
http://67-72chevytrucks.com/vboard/f...play.php?f=206
Mint68 is offline   Reply With Quote
Old 03-18-2013, 04:15 PM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
Speed and performance makes adapter plates as well as many other places, you can also find templates to make the mounts yourself.
Check out the section of the forum dedicated to LSx swaps in the engine and drivetrain section of the forum.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 03-19-2013, 08:37 AM   #5
chasinhiway
chasinhiway's Avatar
I used the dirty dingo mounts and adapters. the motor bolted right to the 6 cylinder towers with what I feel is good clearance.
chasinhiway is offline   Reply With Quote
Old 03-19-2013, 08:44 AM   #6
b.eddy's72
b.eddy's72's Avatar
No need for my input cause this one was answered QUICK
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new.
66 GMC Short Step, 84 Front Suspension, many more mods to come
67 Chevy 3/4 Ton, 327, Auto, Factory A/C
Ya must have been movin cause I was haulin a*$ when I passed you
b.eddy's72 is offline   Reply With Quote
Old 03-19-2013, 11:01 AM   #7
MARKDTN
Just curious why you would do a TH400 with a 5.3? If you have the computer, you may as well put a 4L60E and get the benefits of overdrive.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 03-19-2013, 12:23 PM   #8
1970 C10 MJW
1970 C10 MJW's Avatar
might i suggest you join us over at the LSx swap section. if you go to the home page go to engine and drivetrain section then there is a huge sub forum for LSx swaps
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 03-20-2013, 07:06 PM   #9
jobee1967
Thanks for the info everybody.
chasinhiway, can you give me the particulars on what you ordered from dirty dingo? There are a ton of choices there and I'm not sure what to pick.
MARKDTN, I'm doing a carb swap on the 5.3 so thats the reason for using the turbo 400. I'm a lot more comfortable with a carb and think it fits in a little better with the old truck.
Jason
Old 03-21-2013, 09:59 AM   #10
chasinhiway
These are the adapters I used:
http://dirtydingo.com/store/index.ph...=1_206_305_335
They also sell the engine mount itself that I bought. The passenger side rubber mount has to be trimmed at the bottom and theirs comes trimmed. I called them and told them what I was doing and they told me what would work.
Old 03-21-2013, 11:54 AM   #11
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Jason
You could get a 700r4 and get locking torque converter and overdrive without a computer. Thats what I'd do with a carbed 5.3. I've got one in my 71 with a 402
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 03-21-2013, 11:55 AM   #12
MARKDTN
I will probably be flamed, but to me there is absolutely no reason to carburate an LS. They are made to be fuel injected. It will not cost any more to inject it than carb it and you will be SO FAR ahead in reliability and mileage. Flame away, but that is my .02
'83 K20-TPI
'73 C10
'14 Suburban-DD
